- May 23, 2006
- 1,095
- 2
- 36
SBF Rocker Arms - 1.7, 7075-T6 aluminum, Pedestal Mount
Manufacturer: Erson Cams
Part#: E928089
Category: Rocker Arm
BILLET-ALUMINUM ROCKER ARMS
This high-quality, billet rocker arm is machined from extruded 7075-T6 aluminum; the strongest of aluminum materials. A new pocket design decreases weight and allows more oil to the roller- tip. The tip itself is made from bearing quality steel. For minimum wear under severe conditions, the trunion and pushrod seat are made from chrome-moly alloy steel.
The unique profile of this new rocker decreases deflection without increasing weight. Wider needle roller-bearings deliver better load distribution from high-pressure springs.
These are extruded 7075-T6 aluminum rockers and not vacuum cast aluminum like the ones from cobra or other rocker arms. Best pedestal rocker arms money can buy!
Direct bolt-on rockers for Cobra R/Cobra and 5.0/5.8 Ford small block Windsor engines.
Price from summit was $450.
$350, New in box
Part#: E928089
$350, New in box
