Explorer intake on 93 GT
Discussion in 'Fox 5.0 Mustang Tech' started by Santeeford, Aug 1, 2008.
  1. I was thinking of getting an upper and lower intake manifold from a 5.0 explorer. Im not sure what year it is. I want to put it on my 93 Gt . Is there anything i need to know or any special parts i need to get or modify to fit? Thanks guys
  2. There's an extensive amount of information about this swap on here, I believe there's a sticky? I believe it's off 99-00 Exploders with the 5.0 and it's just about a direct swap...
  3. I actually just got it. And found out its off a 97. Any other help woukld be awsome.
  4. Explorer intake swap.
    I got mine off a 96 Mountaineer with the 19# injectors and 65 MM throttle body for $250.
    The ACT (Air Charge Temp) sensor will probably need to be moved. The GT 40 lower manifold isn't drilled & tapped for it to go into the intake like the stock manifold was. There is a boss cast into the GT 40, but a machine shop will have to drill & tap the new manifold. The best spot for the ACT is the air box if you don't do the drill and tap thing. You get to cut and splice the 2 ACT wires in order to make them long enough to reach the air box. Solder the wire extensions on the existing wires & use heat shrink tubing to cover the splices. Offset the place where you cut the wires so that you don't have a big bulge when you put heat shrink over the 2 wires to cover & protect them. The air box gets a hole (5/8" or so) for the ACT drilled about 1 1/4" down & 1/1/4" in on the front top side near the upper radiator hose. A brass fitting nut from Home Depot or Ace Hardware secures the ACT into the air box.
    If you are very clever, you will find that the ACT connector comes apart so that you can remove the pins. A very small screwdriver releases the lock in the front of the center insert, while another small screwdriver inserted in the back pushes it out. Once the center insert is out of the connector shell, the pins come out easily. New pins are available from AutoZone in a $5 electrical pin kit for Fords. Crimping the pins on the extender wires saves you from having to splice them twice: once to put the connector on and once to extend the wires.
    6 ft black 18 gauge wire
    6 ft green 18 gauge wire
    6 ft 1/4" heat shrink tubing
    1 ft 3/16" heat shrink tubing
    Measure the 2 extender wires & cut them to length, crimp one set of pins on them. Then mate up the extender pins with the wiring harness & slide the 3/16" heat shrink tubing over them & shrink the tubing. Then slide the 1/4" heat shrink tubing over the pair of wires and shrink the tubing. When you are done you'll have about 1" of wire left without heat shrink tubing on it to strip & crimp the new pins on. Stick the new pins in the old connector shell, assemble it and you are done. It looks as good as factory. Some wire loom can be used to enhance the "Factory Look".
    Use the TPS and IAB from your old throttle body. All the EGR passages were there and fit OK. Use you old fuel rails and regulator. You will probably need a new EGR spacer adapter and gaskets. Without the EGR spacer, there is no place to mount the throttle linkage support bracket.
    I used the stock water lines on the Explorer manifold and they connected up to the EGR without any problems. I made a “U” out of ½” copper pipe and sweat soldered it together. Then I used it and some hose with clamps to bypass the leaky heater I have. You don't need heat very often here in Central Florida...
    The vacuum lines you need are 1 small line for fuel pressure regulator, 1 small line for A/C,1 small line for EGR and another small line for the smog pump. One big line at the back goes to the vacuum tree for the power brake & A/C, one big line goes to the PVC valve. The other big line goes out the front for the carbon canister. In a pinch, one of the small lines can connect to the spare port on the vacuum tree. Cap or plug the remaining lines since they aren't needed.
    The stock Explorer linkage didn't come anywhere near fitting, so I made an adapter plate for the throttle linkage so I could use the 65 MM throttle body.
    This is what I did:
    Make a drawing of the position of the old throttle body linkage arm and its angular position relative to the centerline of the throttle body. Remove the ball stud off the explorer TB to make way for the adapter plate. Drill and tap a 10-32 hole in the linkage parallel to the TB shaft. Make an angle bracket out of 1" angle iron 3/8", drill a 3/16” hole in the center of each one of the legs. Then bolt it on where the hole was drilled & tapped. Then make a circular adapter plate out of 1/4" thick aluminum to bolt the two linkage arms together. Then bolt the aluminum plate to the existing linkage, and the angle bracket. Next mount the arm with the ball stud off the old throttle body on the adapter plate using the drawing to get the angle correct. You will need an aircraft type countersink for one of the bolts that secures the plate to the explorer linkage arm. It ends up being under the arm with the ball stud for the linkage. It works great and looks neat.
    The Explorer TB could have been real simple if I had a gas welding torch or taken the TB to a welding shop. Just grind the mushroomed part of the TB shafts so that you can pry the linkage arms off. Then swap the stock arm onto the Explorer TB and braze it onto the shaft. It Takes about 3 minutes or less worth of work with the torch, so it shouldn't cost much.
    I didn't have access to a welder, so I fabb'ed the plate in my shop. I took about 1.5 hours to do it, it was a measure, cut, and fit type of operation.
    Also see http://www.veryuseful.com/mustang/tech/engine/ConvertingExplorer65mmTB.pdf for modifications to adapt the 65 MM Explorer TB to a Mustang
    Vacuum line connections:
    One large vacuum line from the upper front goes to the carbon canister
    One large vacuum line from the rear goes to the vacuum tree.
    One small line in the front feeds the Smog pump solenoid control valves on the rear of the passenger side wheel well..
    One small line in the rear goes to the fuel pressure regulator.
    One small line in the rear goes to the EGR suction regulator.
    One large line in the rear goes to the PVC valve.
    Diagram courtesy of Tmoss & Stang&2birds - Typical Vacuum Routing for a Fox stang 5.0: [​IMG]
    See the following website for some help from Tmoss (diagram designer) & Stang&2Birds (website host) for help on 88-95 wiring http://www.veryuseful.com/mustang/tech/engine/
    Here's some tips...
    Tools: a good torque wrench is a must have item. A razor blade scraper that holds a single edge razor blade from Home Depot or Ace hardware is another handy thing. Get a Chilton or Haynes shop manual - you'll need it for the bolt torques and patterns. The intake manifold has an especially odd pattern. You'll need access to a timing light to set the timing after you re-stab the distributor. Look in the A/C repair section for the fuel line tools. They look like little plastic top hats. You will need the 1/2" & 5/8" ones. The hat shaped section goes on facing the large part of the coupling. Then you press hard on the brim until it forces the sleeve into the coupling and releases the spring. You may need someone to pull on the line while you press on the coupling. Put some motor oil on them when you put the line back together.
    The A/C Compressor comes off with lines still connected. Mark all the electrical, smog and vacuum lines with tags to help you remember where to re-connect them. If you have a digital camera, take several pictures.
    Whatever you do, don't skimp on cleaning the gasket surfaces. New gaskets need to seat against bare metal and not the residue left from the old gaskets in order to seal leak free. This is the most time consuming and tiresome part of the job. I suggest that you make good use of a shop vac while you are scraping and cleaning to avoid getting the old gasket material lost inside the engine. Look for little things that need to be replaced like the short hose from the thermostat hosing to the water pump, damaged vacuum lines and hose clamps that are rusted or broken.
    Plan on cutting the thermostat to water pump hose, or removing the thermostat housing. Also plan on removing the distributor to get clearance to remove the intake manifold. Remove #1 spark plug, stick your finger in the spark plug hole and crank. When your finger gets air moving past it, stop cranking. Turn the engine until the timing marks line up with the pointer. Now you can pull the distributor out.
    My favorite trick that saves time and effort is the stay in place gasket. Be sure that you scrape (don't use a wire brush) all the old gasket material off, then clean all the surfaces with acetone or MEK.
    When the surfaces are clean, use weather strip adhesive on the head to manifold surface. Also use the weather strip adhesive on the side of the gasket that mates to the head. When you are done, the head surface and the gasket surface that mate together will have weather strip adhesive on them. Follow the instructions on the tube or can and when it gets tacky, press the gasket down on the head.
    Clean the area where the rubber rails mount to the block in front and in the rear with more acetone or MEK and do the same trick with the weather strip adhesive that you did to the heads.
    Coat the rubber seals and the gasket area around the water passages with lots of Blue Silicone gasket sealer and put it together. TADA! no leaks, and no gaskets that shifted out of place.
    Fuel injector seal kits with 2 O rings and a pintle cap (Borg-Warner P/N 274081) are available at Pep Boys auto parts. Cost is about $2.74 per kit. The following are listed at the Borg-Warner site ( http://www.borg-warner.com ) as being resellers of Borg-Warner parts:
    http://www.partsplus.com/ or http://www.autovalue.com/ or http://www.pepboys.com/ or http://www.federatedautoparts.com/
    Most of the links above have store locators for find a store in your area.
    Use motor oil on the O rings when you re-assemble them & everything will slide into place. The gasoline will wash away any excess oil that gets in the wrong places and it will burn up in the combustion chamber.
    Plan on doing an oil change within 2 hours of run time on the engine. This will get the debris and coolant out of the oil pan.
    Consumable items:
    Upper manifold gasket
    Fel Pro 1250 or equal lower manifold gasket set.
    Short formed hose between thermostat hosing and intake manifold
    6 ft 7/64" or 1/8" vacuum hose
    2 ft 1/2" heater hose
    1 1/2 ft 5/8" heater hose
    Blue Silicone sealer
    ARP antiseize or equal for the bolts
    4 each 3/4" hose clamps (spare item in case the old ones are bad)
    4 each 1/2" hose clamps (spare item)
  5. any special gaskets or other special parts i might need?
  6. Everything is listed in the parts list I posted. The only parts that might be hard to find are the pins for the extender for the ACT sensor if you decide to put it in the airbox. Everything else is stuff you can get from any good auto parts store.
    See http://forums.stangnet.com/643651-useful-technical-thread-index.html for all kinds infor on upgrades and bolt on items.
    If you want more Explorer/GT 40 tech info, see http://forums.stangnet.com/551505-freakys-official-explorer-gt-40-intake-thread-56k-dont-bother.html
  7. I just read that on the 97 intakes, the EGR cant be installed. Is this true? If so is there anything i can do?
  8. If there is an elongated passage under the throttle body opening, a round passage in the middle of the lower and rectangular passages on each head side of the lower you will be good to go. Some intakes from early 1997 have these passages cast in so hopefully you'll be in luck. The alternatives are to fab up an external EGR setup or run without EGR, but you'll have to have the computer tuned to run without it. See if you can get Michael Yount to explain his non-EGR setup.
  9. hope this isnt old news brought up but i'm wanting to do this by this weekend. a part mentions to move the act sensor to the airbox. i currently am using the stock air box but eventually going to cai (fendermount) would that still somehow be possible or am i better of tapping a hold for the act?
  10. Drill & tap the hole for the ACT if the lower manifold has the boss cast into it. The computer is calibrated for the ACT to be in the manifold. Putting it in the air box is the next best thing. It works OK, but probably isn't optimal.
    The ACT uses a 37/64" drill and a 3/8" pipe tap. See Industrial Supply Equipment from MSC Industrial Supply or McMaster-Carr if you can't find the drill bit or tap locally.
  11. 3/8 standard machine thread?
  12. another question, my egr vacuums are currently not hooked up. since the car is working fine with out it, can i just put the tb right up to the upper without the egr spacer? or is it a better idea to keep and run everything for the egr?
  13. 3/8" NPT (National Pipe Tap, taper thread)
