On my 90 gt I have noticed that my fogs will only turn on when the headlights are in use.I thought we could turn fogs' on when the parking lights are in use? If so is my fog/headlight switch at fault?
My 93 is the same way, I believe its the way it is supposed to be, Im not a mechanic but I think the manual says the same thing. I bet there is some type of aftermarket bypas switch we could get to fix it, there is an aftermarket trick for everything!
Go there, good write up if you want fogs with high beams or parking lights. It is a good idea to keep your headlight switch from burning up, which this solves.
