FS: Fully Built 1992 LX 5.0 Hatch 515rwhp
Discussion in 'Fox WTB/Trade Cars & Parts' started by Vegas.SE, Aug 23, 2010.
Thread Status:
  1. 58,000 Original Miles
    Never been hit
    Clean Carfax
    Strawberry Red
    Car has over $16,000 in mods alone into it. Car has no dings or dents, just a couple little touch up areas from small chips over the years. Interior is mint with no stains, rips, cracks or tears.
    Dart Sportsman Block
    4 Bolt Main Caps
    Callies Internally Balanced Forged 347 Crankshaft
    Compstar Forged H-Beam Rods
    Diamond Forged Pistons
    AFR Street Port 165cc Aluminum Heads
    ARP Head Studs
    Ford Racing Aluminum Valve Covers
    Comp Cams High Energy Pushrods
    Scorpion Premium Roller Lifters
    Trick Flow Billet Dual Timing Chain
    Comp Cams Blower Camshaft
    Powerforce Harmonic Balancer
    Clevite Rod Bearings
    ARP Rod Bolts
    Clevite Main Bearings
    ARP Main Bolts
    Moroso Billet Main Girdle
    Ford Racing Aluminum Radiator
    160degree Thermostat
    3100cfm Twin Electric Fans
    Custom Aluminum Shroud w/temp adjustment module
    Weiand High Performance Water Pump
    Upper Radiator Hard Pipe
    Lower Radiator Hard Pipe
    Custom Aluminum Overflow Can
    Twin Custom Aluminum Breather Can
    Custom Tapped Valve Covers for twin -12 breathers
    All new seals, gaskets, bearings
    Ford Racing 42lb Injectors
    Trick Flow Billet Fuel Rails
    255L Walbro Fuel Pump
    Trick Flow Fuel Pressure Regulator
    Snow Performance Stage 3 Meth Injection System
    MSD 6AL
    MSD Coil
    Accel Dual Sync Distributor
    Ford Racing Plug Wires
    130 Amp Alternator
    Fast XFI w/data logging + TC Stand Alone
    Full InsaneSpeed custom engine harness
    Edelbrock Performer RPM II Intake Manifold
    ARP Manifold Bolts
    Trick Flow 75mm Throttle Body
    Powerdyne Supercharger
    928 Billet Impeller
    928 8 Rib Billet Pully 2.5inch
    928 Billet Blower Belt Tensioner
    Vortech 8 Rib Crank Pully
    Internal Kevlar Belt
    Gates Blower Belt
    High Speed Bearings
    High Speed Shaft upgrade
    Aluminum 4 inch intake
    K&N 4 Inch Filter
    Clear Headlights
    Smoked Taillights
    15% Tinted Windows
    New 5.0 SC Emblems
    Cervini 2.5 inch Cowl Hood
    Saleen Whale Tail
    Cobra Grill w/Pony Emblem
    Cobra R Wheels Chrome
    275/40/17 Mickey Thompson ET Street Drag Radial Rear
    245/45/17 Michelin PS2 Front
    Car Painted 2010 Kona Blue
    Eibach Lowering Springs
    Eibach Shocks
    Eibach Urethane Shock Bushings
    Eibach Urethane Control Arm Bushings
    Eibach Sway Bars
    BBK Rear Upper Control Arms
    BBK Rear Lower Control Arms
    BBK Urethane Control Arm Bushings
    Kenne Brown SubFrame Connectors
    Upper + Lower Heavy Duty Torque Box (welded in)
    Ford Racing 3.55 gears
    Eaton Posi
    Aluminum Driveshaft
    UPR Rear End Bracing
    UPR Stud Girdle
    BBK Shorty Headers
    BBK Header Gaskets
    BBK X-Pipe
    Flowmaster Catback
    TKO 600 Transmission
    26 Spline Shaft
    Steel SFI Bellhousing
    TTC Shifter Mechanism
    New Crossmember
    HD Urethane Cross Member Bushings
    HD Urethane Trans Mount
    Cryo'd Tremec Slip Yoke
    HD Pilot Bearing
    New Shift Fork
    New Speedometer Cable
    New Throttle Cable
    Science Friction Kevlar 26 Spline Clutch
    Lightweight Flywheel
    Steeda Tri-Ax Shifter Handle
    Hurst Pistol Grip Shift Knob
    Autometer Boost Gauge
    Autometer Coolant Temp Gauge
    Innovate Wideband Gauge
    Below Radio Gauge Mounting Plate
    Short Stop Front Slotted Rotors
    Hawk Street Pads
    At 10psi
    Price = $14,500obo
  2. damn how much for that sexi azz supra in the back thats my dream car haha
  3. haha, that Supra is being built for a major magazine. Literally everything on the car is full custom and most are one of a kind things. It has $20,000 in paint and body work alone and is a nick over a $250,000 build.
Thread Status:
