fuel help needed
Drives a 5
227
Epping, NH
85 LTD 5.0 CFI not starting:
getting spark
key on engine off, fuel pump does not prime
when fuel pump test port is grounded, fuel pump primes
(has pressure at shrader valve after being jumped, holds pressure)
inertia switch is down (also tried bypassing)
tried new fuel pump relay
Since the pump comes on when jumped, that means the pump is ok? What else is there to check since the inertia switch and relay are ok? This is an electrical problem since I can get the pump to prime/have fuel pressure, correct? Thanks for any help, I want to get this diagnosed and fixed!!
