Alright gents, doing a little bit of forward planning. I want to work on the Mustang over the winter to update various suspension and rear end bits, but unfortunately the garage is detached, brick, and no insulation or inside walls. Just the outer face brick on all four sides and the inner cinder block. I would be interested in a lower cost solution for heating and am considering propane or a kerosene/diesel heater if I can figure out a way to keep things properly vented. Garage only has two glass block windows with vents in the middle that are literally right next to my spot (don't want that heater blowing propane flames directly at my passenger door!)
What solutions have you found? Electric heaters? Is propane clean burning enough to keep a heater in a poorly vented garage?
Would love to have a wood stove or waste oil burner out there but not so sure about chopping up the roof to make that work with a chimney...
Ideas and suggestions appreciated. I want to figure this out while it's still hot outside so i'm not fighting through numb fingers and missing sunday football telecasts putting together a heater!
