- Aug 30, 2003
- 20
- 0
- 1
so i'm still trying to get my new trickflow setup running right. I've got a leak on the end rails front and back of the lower intake. i pull off the upper and the gasket that is between the upper and the spacer is soaked in gasoline.
now the car has been running SUPER rich even though i've tweeced the maf curve and injector size, still got work there. and i wasn't sure that my injector on cylinder #1 was firing, because that header tube has no discoloration (other 7 do) but the gasket and spacer are soaked at the front and there is some in the middle and the back too. what would (or could) cause this.
You guys are great and i appreciate any help
