I read some where in a ford forum where this guy was braging about 400 pound ft of torque at the rear wheels. My scooter has more rear wheel torque than that. The mistake he made was that ,that was
the flywheel torque as measured at the rear wheels. With the proper gearing a driil motor with 2 pounds feet can be geared to produce 2000 pounds feet of torque. The only problem with that is by using
a gear reduction of that size the rpms are like 1 rpm with is not practical. If we change the gears by
changing the drive gear with the driven gear we can make 1 million rpm but the torque will only be
.002 pounds feet which is also un useable. The trick is finding a middle ground. Basicly you can push very hard but not very fast or you can push very fast but not very hard.
