You just use a 12pt socket.
Here's a couple more tips for you:
While you have the lower intake off - it is does NOT have a threaded port for the ACT in the #5 runner, drill it and tap it so you can move the ACT from the TB-MAF powerpipe to the #5 intake runner. You can also tap the KB discharge to do the same thing. Chances are your tuner will want the ACT there so it sees boost and pulls timing when things get too hot.
What MAF are you running? We always suggest that our customers use a 90mm LMAF - it's good to 450 RWHP or so and you will not get that high, plus it's OEM quality. You will need a chip for it to work right though. Astock MAF will peg - usually C&Ls and Pro-Ms give driveability problems.
Be sure you connect the fuel pressure regulator to the BOOST side of the blower and use something to keep the hose ends from blowing off - even zip ties will work. If you do not connect it to the boost side of the blower, the motor will go lean.
Use a stud on the back rear lower intake (driver's side) to connect the KB to the lower. Then use a distributor wrench to tighten the nut - otherwise it is VERY difficult to get to.
When you are putting the blower on, leave the EGR tube off, then torque the blower to the lower. If you connect the EGR tube first, it will hold the blower up slightly and you will get inaccurate torque readings and you may blow the upper/lower gasket.
Or use a block off plate on the EGR port and delete it and plug the hole in the header with a 5/8" flare cap and have it shut off in the chip. Unless of course you have smog checks. The EGR normally doesn't hurt a thing because it only works at part throttle when the motor is warm - but with a KB - it recirculates exhaust gases creating even more heat at part throttle - something a KB does quite well on its own.
When you get the blower on the car and take it to the track - with a KB you cannot hot lap it. You have to let it cool between runs - or you'll get detonation - those blowers are HUGE heat sinks and need to be cool to work well.
If you need any guidance, I'd be happy to help - I used to run a '95 Vert with a KB and I think it was probably one of the quickest 5.0 Verts on drag radials it went 11.1/123. Plus we have tuned TONS of 94-95 KB cars. Email me at
[email protected] and I'll be happy to help.
Don
