Got $100 for my B-day what do I get?
Discussion in '2005 - 2012 (S-197) Mustang' started by walter, Oct 21, 2009.
  1. Gearbanger 101 That's my secret, Captain. I'm always angry!!!
    Aug 11, 2002
    Message Count:
    11,331
    56
    98
    Ontario, Canada
    Let me see if I can shed some light on this one for you....
    1. I have yet to see a Modular overheat with under drive pulleys. It may have been an issue with the old Fox Body cars, but the S197's with their more modern cooling system and generous radiator surface area doesn't seem to suffer at all from this. Besides, if worse comes to worse, you could always swap out your stock 192-deg thermostat for a 180-deg one.
    Look at it this way. I'm running under drive pulleys, a pair of 10" electric fans and an electric water pump on my 5.4L hauling nearly a 6,500lb vehicle weight around on a daily basis and my truck never moves out of normal operating temperature. Hell, my fans hardly ever even kick on. :nice:
    2. Unlike OHV engines, Modular engines are "internally balanced". Lightening up weight at either end of the crank shaft isn't going to throw a wrench into the mix one way or another. As long as said weight is neutral balanced, there won't be a problem.
    This is also why the 4.6L, 5.4L an even the 6.8L have all used the same harmonic dampener over the years. :)
  2. walter Founding Member
    Aug 13, 1998
    Message Count:
    1,068
    46
    Houston TX
    It would be pretty pimp to have the engine spin like crazy....
    Maybe adding a 5.0L stroker later and that C&L intake manifold with a nice tune would make a killer N/A motor. Just pondering...
    Thanks for the info I'll look into that.
  3. timeless2 Vi Veri Veni Versum Vicus Vici
    Apr 22, 2005
    Message Count:
    10,049
    27
    88
    the Shadow Gallery
    Awaits walter's impending "I spun a bearing" thread. :p
  4. Gearbanger 101 That's my secret, Captain. I'm always angry!!!
    Aug 11, 2002
    Message Count:
    11,331
    56
    98
    Ontario, Canada
    It would be a cool set up, but I wouldn’t lengthen the stroke of an engine I was intending to be a “screamer”. Lengthening the rod increases the work and time it takes for one complete revolution of the engine. Increasing the displacement by widening the bore is the way you want to do it. Which unfortunately is limited with our close bore spacing. :(
  5. walter Founding Member
    Aug 13, 1998
    Message Count:
    1,068
    46
    Houston TX
    Lol I know, in my Nissan days I used to champion the 2.4L long stroke 4cyl over the 2.0L Turbo though revs and boost were limited by the stroke. Still fun no less.
    I may just have to add some boost to the setup or better swap in the new 5.0L when it comes out as a crate engine from Ford Racing. I wonder what will be interchangeable with the 4.6L.
  6. Gearbanger 101 That's my secret, Captain. I'm always angry!!!
    Aug 11, 2002
    Message Count:
    11,331
    56
    98
    Ontario, Canada
    Seeing as it’s supposed to be a completely new design, I don't imagine much of anything from the old 4.6L is going to transfer over unfortunately. The bore spacing is supposed to be much wider, so heads and intake are out....as well as exhaust components. Intake maybe?....but then I imagine there will be subtle enough differences in them to make the previous model unusable. :(
  7. chiefstands New Member
    Oct 22, 2009
    Message Count:
    Battle Ground Washington
    Tons of great ideas for $100 Seems like sequentials are the #1 mod from my world lately,
    Hood Strut makes it easy when you need to be working under the hood, and there are custom painted versions available. Add some chrome engine caps a little at a time for some underhood bling.
Share This Page
