Been there done that...there is no way to accomplish this without flycutting the pistons. The issue is not with the size of the cam, but the fact that the factory valve reliefs simply will not support a 2.02 intake valve used in a 19 degree setup (TFS TW heads get around this only by angling the valve). The stock reliefs issue is they are not wide enough, despite the added depth of the cam. Be sure to clay them as you go using playdough. It's a good idea to put a little oil on the playdough so it doesnt stick. Use an old headgasket, tq the heads down and use a solid lifter while assembling the valvetrain while claying. I believe you will want at least .030 clearance IIRC. The 1.7 rockers will only worsen this issue.
A 24# injector should support this just fine as it will make @ 320 rwhp depending on the dyno etc. If needed just bump the fuel pressure a tad.
