I am thinking about getting my TFS Track Heat heads ported this winter. Where is a good place to send them I live in Washington State. Any idea how much it would cost?
Thanks, Black 93 Fox
Black 93 Fox said:Well I want to put in the Trick Flow stage 2 cam but I dont know if it will fit. Im not sure if it will have problems with the pistons or not. I just want the stage 1 port I think thats enough. My heads are brand new they only have 1000miles on them from the break end period for the new motor so I wouldnt think anything needs to be changed even if I put in the bigger cam cause I think the track heat head can hold up to the stage 2 cam?? I think im gona do a little more shopping around then I might send them to foxlake this winter while the car is apart.
vristang said:The only place here in WA that I can think of to ask is Brads Custom Auto in Seattle (I think that is the name, and I think they're in Seattle). They have a pretty wicked autocross car at the B.C.C. Mustang show each year, and they have been very helpfull/knowledgeable each time I have spoken to them.
Might also call up Jim Greens in Lynnwood to see if they will do porting, or know somewhere who will. Also, I think the Mustang exclusive shop (used to be Mikes Mustangs, or at least some of the same guys who worked there) is still in Marysville/Everett.
Guess I could think of more than one place.
Grn92LX said:Stick with what's proven rather than some no name machine shop. A port job done wrong will cost you money and slow you down/barely make you faster.
What pistons do you have? Theres a lot more to valve spring specs than max lift. Track heat springs aren't too good once you get into custom cams. Ported TW heads are gonna want a different cam to really shine.
