- Mar 30, 2005
- 388
- 0
- 0
Have a 1993 GT. All of my other sensors are new so I decided to change the one sensor that wasn't new which was the BAP sensor which code 22 refers to.
After clearing codes from memory I run the KOEO which gives me codes for TAB and TAD which aren't connected. Then I run KOER which gives me the same codes.
But then after I drive for a little and come back and run the KOEO, I get a code 22 stored in continuos memory.
KOER then may or may not give me the continuous 22.
I have tried two brand new Motorcraft DY-530 (E7EF-12A644A1A,A2A)
So then I decide to put my old OEM BAP sensor back on and repeat the entire procedure above and DO NOT get a code 22!!
Any reason why two new sensors would do this and old one doesn't?
Also, is it possible for a code 22 to make hydrocarbons increase by 3 times the normal amount?
