help with coupe
Discussion in 'Fox 5.0 Tuning' started by ztockz28ss, Dec 7, 2007.
  1. ztockz28ss New Member
    Dec 7, 2007
    Message Count:
    hello everyone.im new to this site,im from houston, wanted to know if anybody could help me on thisi have a 93 coupe,with a 306,e303 cam trickflow heads,edelbrock intake,longtubes,373s,19lb injectors,the car was running a lil rough so put it on the dyno to check a/f mixture,it was 14.1 but then at 3800rpms the car leans out to 16.1,i tried to pull the codes,but scanner wont read,i hooked it up to diagnostic port,does anyone have any idea,what it could be:shrug: :shrug:
  2. strtrcr50 New Member
    Jun 22, 2006
    Message Count:
    2,568
    Previously from Dirty Jerzey exit 7a
    Try pulling the codes with a test light. Sometimes my scanner won't pull them. BTW, what fuel pump do you have in that car? And you prob need bigger injectors/mass air or a tuner.
  3. ztockz28ss New Member
    Dec 7, 2007
    Message Count:
    not sure on the pump the guy who the car before me said he upgraded the pump,but not sure,i was thinking about upgrading the fuel injectrs to 24lbs,but not sure if thats the problem.how do i pull the codes with a test light,on the dyno at 3800rpm it was making 215hp and 270trq but was leaning out,
  4. strtrcr50 New Member
    Jun 22, 2006
    Message Count:
    2,568
    Here's the link I was given by JRichker.
    link
    Check out this thread too.
    link
  5. squeak93 Active Member
    Jun 2, 2005
    Message Count:
    1,105
    36
    Joplin, Missouri
    I would say upgrade to 24's, get a good 255 pump and adj fuel pres reg. You have to be maxing out those 19's which is why you lean out on up top.
  6. ztockz28ss New Member
    Dec 7, 2007
    Message Count:
    thats what im thinking,i tried pulling the codes but didnt have no luck,bout to try again,
  7. squeak93 Active Member
    Jun 2, 2005
    Message Count:
    1,105
    36
    Joplin, Missouri
    With a good running set up you should be putting down in the 300 range. Get some bigger injectors and a nice dyno tune so you know what the a/f is.
  8. 90bluegt Founding Member
    Dec 9, 1999
    Message Count:
    597
    You are really maxing out the injectors, I'm in the 300 horse range and my 24#er's hit the 90% range so you have to be over what those things can handle. Upgrade those and the mass air meter, then you should be better. Your going to need to get a tune for the car as well and that will help.
  9. ztockz28ss New Member
    Dec 7, 2007
    Message Count:
    thanx guys i installed 24# injectors, and calibrated mass,and the car idles alot better and runs alot better,need to get it on dyno and check a/f ratio,what times are you guys running,i still cant wai to c what it will run
  10. justintx75 New Member
    Dec 24, 2006
    Message Count:
    36
    where at in houston are you dynoing ure car?
  11. ztockz28ss New Member
    Dec 7, 2007
    Message Count:
    i had took it to straightline performance over in pasadena.sorry i too months to answer,didnt have a computer
  12. 90bluegt Founding Member
    Dec 9, 1999
    Message Count:
    597
    My car has gone 13.6 at 105 three or four years ago, changed the injectors and maf since then as well as tuned the car. Runs stronger now.. :)
    BTW that was spinning all the way through 1st and 2nd gears, then finally hooking up in 3rd.
    Car is getting completely overhauled now though, wifey gave me permission to strip the car and rebuild so that's what I'm doing.. :)
    Twin turbos here I come!!!
Share This Page
