Need more info. What particular size afr head?165 185cc etc. what's your intended use? Street? Strip? Mostly street/some track times? Manual trans/auto? What rear gear ratio? Do you have a good MAF sensor/injectors/fuel pump? What is the exhaust set up? Shorty headers? For the best results answer these questions and then look into a custom grind cam from flowtechinductions.com,bullet cams,Anderson ford,and or another cam designer(I used Mr. Friedentag aka Freezy). If you want a fairly safe off the self cam look into a trick flow stage 1 or comp cams 266/270 hr series. Stay away from the ford letter cams(e/b cams). They work ok but there are a ton of better designs these days.
