Alright guys what do you think it will run its a 90 gt 306 3 bar gt 40 heads mild port job valve job e cam 1.6 roller rockers ported explorer intake no smog stuff no a/c stuff 30lbs injecters 255lph pump boosta pump vortech V-3 7psi of boost adj. FPR upr upper and lower contol arms 4:10gears performance automatic AOD f springs New bushings ball joints tie rod ends MM steering shaft aluminum drive shaft sub frame contenters full weight car 245/50/16 nitto 555r drag radials that's about it tuned with quarter horse by a buddy no dyno numbers it all got 1500 miles on it I've been building it for the last 3 years so do you guys think I can get high 11s out of it the way it is wideband says air fuel is good what kinda horsepower do you guys think it makes
