I've had this problem ever since i got it out of storage. It starts fine when the car is cold. But once its been running a while up to operating temps when u shut it off...it starts slow like the batt is weak or wont start at all but once it hits the end of its trying to start and your still holding the key all the lights on the dash die...just turns over once maybe 2-3 times but not fast enough for it to pop off....
Ive completely changed everything from the batt ground all the way to the starter in the starting wiring cycle. Batt ground, battery, positive batt cable, starter solinoid, coil, starter cable, engine ground, and starter. not avail.
I have a Crane Frieball igntioin and i found the ground was loose and thought that might be the problem...so when it was cold i unhooked the ground and tried to start it. Just turned over fine, didnt fire, as assumed. Hooked it back up drove around got it hot, came home shut it down adn tired to start it....2-3 slow turnover and it popped off. Shut if off again and tried to start it 2 turn overs and it was dead. Unhooked the ground from the igntion box and tried it still turned over slow 2-3 times, so i guess that rules the igntion box out too w/o throwing stupid money at parts and replacing it...
any ideas? thanks
also a little side note that might have something to do with it not sure...when i was slam gears racing it would cut out when he slammed the gear and when u left off the gas it could cut back on....but it hasnt done it recently its been hit and miss and hasnt done it for a while...might ahve been the loose ignition ground...
any ideas? thanks
