It seems that Comp Cams and Crane Cams directions are a little different and I would like to know which one is correct. Both procedures are listed below and the major difference is highlighted. It seems that Comp has you turn the wheel to the average of your two points. Crane wants you to adjust the piston stop until the two stop points are exactly the same and that is your TDC? I can see how they would both work but I think Crane's is more exact. Who has done this before? Thanks
CRANE CAMS
Begin the procedure by first mounting the degree wheel on the end of the crankshaft securely, and rotating the engine to approximately T.D.C. Mount the pointer and line it up at zero on the degree wheel. Now rotate the engine to move the piston down into the cylinder. Install your positive stop device into the spark plug hole and extend the bolt. Now hand turn the engine (do not use the starter motor or you will put a hole through the piston), rotating until the piston comes up and stops against the bolt. Look at the degree wheel and write down the number of degrees shown by the pointer.
Hand turn the engine in the opposite direction until the piston comes up and stops on the bolt again. Go back to the degree wheel and write down the degrees it now reads. Add these two readings together and divide the answer by two. Now either move your pointer by this many degrees, or carefully loosen the degree wheel (without disturbing the position of the crankshaft) and move the wheel this required amount. Re-tighten the bolts, and rotate the engine again making sure that the readings on each side of T.D.C. are equal degrees away from zero. If they are, the zero on the degree wheel will now be the true T.D.C. point. Remove the positive stop device from the spark plug hole, as this procedure is complete.
COMP CAMS
: Position the #1 piston at Top Dead Center (TDC). Attach the degree wheel to the balancer or crank
socket, and install the assembly on the crankshaft. The crank may be rotated from either the front or from the
flywheel end. Obviously, if the engine is in the car, you must rotate from the front. Remember, the greater the
leverage, the smoother the crank rotation, and the more accurately you can rotate the crankshaft. Install degree
wheel and pointer, and set the pointer to zero on the degree wheel. Note: Never use the starter to turn the
engine while degreeing a cam.
Step 3: Rotate the crankshaft opposite the engine rotation direction about 15-20 degrees. This will lower the
piston enough to permit the installation of the piston stop in the #1 spark plug hole. Rotate the crankshaft
clockwise until the piston hits the stop, and record the number indicated on the degree wheel. Next, rotate the
crankshaft counterclockwise until the piston hits the stop from the other direction, and again record the number
Step 4:
Remove the piston stop after marking the two points on the degree wheel. Rotate the crankshaft to the
midpoint of the two marks (this is determined by adding the two points on the degree wheel together, then
dividing by 2). This point is TDC for cylinder #1.Without rotating the crankshaft adjust the degree wheel to read
0 degrees at the pointer. You are now ready to locate the intake lobe center line relative to TDC. If you are not
absolutely sure that your zero degree mark is set at TDC, repeat this procedure. This step is critical to proper
camshaft alignment.
CRANE CAMS
COMP CAMS
Step 4:
camshaft alignment.
