i hate these threads but...
Roadblock
208
VA
the stang has been sitting aobut a month, last i drove it i was doing burnouts and doughnuts in the yard and parked it, now i went to start it last night and it cracks idled once like **** and then stalled out i checked this:
plugs are getting fire
injectors are getting current so i assume they are firing, after a while i smelt gas
alt is making power
oil pressure rises while it cranks
fuses are good
everything electrical works (lights wipers ect)
nothing has happened to the car other than not being driven
i get off at 4 and will be working that horse til she runs.....
anyideas on what i may have missed?
Cranks OK, but No Start Checklist for Fuel Injected Mustangs
1.) Remove push on connector from starter solenoid and turn ignition switch on. Place car in neutral or Park. Remove coil wire from distributor & and hold 3/8” away from engine block. Jumper the screw to the big bolt on the starter solenoid that has the battery wire connected to it. You should get a nice fat blue spark.
A.) MSD or Crane ignition box if so equipped
B.) Coil
C.) TFI module
D.) PIP sensor in distributor
E.) ECC relay next to computer - look for 12 volts at the fuel injector red wires
F.) Fuse links in wiring harness - look for 12 volts at the fuel injector red wires. All the fuse links live in a bundle up near the starter solenoid.
G.) Ignition switch - look for 12 volts at the ignition coil red/lt green wire.
H.) Computer
See the following links for wiring diagrams...
http://www.autozone.com/servlet/UiB..._us/0900823d/80/16/71/3c/0900823d8016713c.jsp for 79-88 model cars
http://www.autozone.com/servlet/UiB..._us/0900823d/80/19/59/5a/0900823d8019595a.jsp for 89-93 model cars
http://www.autozone.com/servlet/UiB..._us/0900823d/80/1d/db/3c/0900823d801ddb3c.jsp for 94-98 model cars
2.) Spark at coil wire, pull #1 plug wire off at the spark plug and check to see spark. No spark, possible failed items in order of their probability:
B.) Distributor cap
C.) Rotor
D.) Spark Plug wires
Two reasons:
Clue – listen for the fuel pump to prime when you first turn the ignition switch on. It should run for 5-20 seconds and shut off. To trick the fuel pump into running, find the ECC test connector and jump the connector in the lower RH corner to ground. See http://www.mustangworks.com/articles/electronics/eec-iv_codes.html for a description of the test connector. If the relay & inertia switch are OK, you will have power to the pump. Check fuel pressure – remove the cap from the schrader valve behind the alternator and depress the core. Fuel should squirt out, catch it in a rag. Beware of fire hazard when you do this. In pinch you can use a tire pressure gauge to measure the fuel pressure. It may not be completely accurate, but you will have some clue as to how much pressure you have.
No fuel pressure, possible failed items in order of their probability:
C.) Clogged fuel filter
D.) Failed fuel pump
E.) Blown fuse link in wiring harness. Look for 12 volts at the Orange/Lt Blue wire on the fuel pump relay. The fuse links live in the wiring harness near the starter solenoid.
F.) Fuel pressure regulator failed. Remove vacuum line from regulator and inspect for fuel escaping while pump is running.
Fuel pressure OK, the injectors are not firing.
A.) A Noid light available from Autozone, is one way to test the injector wiring.
B.) I like to use an old injector with compressed air applied to the injector where the fuel rail would normally connect. I hook the whole thing up, apply compressed air to the injector and stick it in a paper cup of soapy water. When the engine cranks with the ignition switch on, if the injector fires, it makes bubbles. Cheap if you have the stuff laying around, and works good too.
a.) Pull an injector wire connector off and look for 12 volts on the red wire when the ignition switch is on.
b.) No power, then look for problems with the 10 pin connecter (salt & pepper shakers at the rear of the upper manifold).
c.) No power and the 10 pin connections are good: look for broken wiring between the orange/black wire on the ECC relay and the red wire for the 10 pin connectors.
4.) Spark & fuel pressure OK.
A.) Failed IAB (no airflow to start engine). Press the throttle ¼ way down and try to start the car.
C.) Engine ignition or cam timing off: only likely if the engine has been worked on recently).
HO & 351W 1-3-7-2-6-5-4-8
Non HO 1-5-4-2-6-3-7-8
E.) No start when hot - Press the throttle to the floor & try starting it if you get this far. If it starts, replace the ECT.
Did you try to start it again? It is not that uncommon for this to happen to a car that's been sitting awhile. Junk builds up everywhere imaginable, especially if the car sits outside. The fuel filter could have something in it, there could be condensation, or as stated, your mass air sensor or idle air controller could be dirty. Try cleaning those. If the car starts but will not hold idle, try revving it a little (not WOT) to clean everything out.
yeah everything sounds liek it should have worked the pump primed and all...just didnt start when it did idled it was reallly choppy and if we gave it gas it died asap
I just started my car 2 days ago after it sitting since mid october. When I went to start it, it would crank but showed no signs of firing. I smelt fuel after a while. Turns out my TFI mysteriously went bad. Put a new one in and it fired right up.
I would clean maf, make sure its got fuel pressure, the pump is priming, check inertia switch if pump isnt priming etc....if the injectors are firing I doubt its the tfi since that controls them.....Look at the plugs to help see whats going on too
To me that sounds like you are running lean. I would check the fuel pump, do a pressure AND a volume check, also maybe your fuel filter is mega clogged :D. Keep in mind that I could be totally wrong
Even though you smelled gas, I would confirm that the injectors are firing. They receive key-on 12 volts and the computer controls the ground to them. A noid light works for this testing.
The guys' Fuel pressure confirmation idea is good.
I like the ISC/IAC idea. On a SD car, you can remove a small manifold vac-line on something unimportant to assist a weak ISC. I dont know what kind of effect that has on a MAF car though.
Have you tried carefully using starting fluid, etc to see if it wants to run for more than a split second(dont use much - that stuff is hard on the motor)?
Random thoughts in the wee hours.
Good luck.
