I Need A New Power Steering Rack!
ReefBlueHatch
682
96
39
Central KY
I'm so happy I just found a puddle of fluid on the floor, okay not really. The breather tube popped out with fluid in it so it looks like I need a new rack. I'm looking for recommendations on where to get an affordable remaned power rack that's decent because money is really tight. I also want to do outer tie rods and poly rack bushings, anything else I should do?
Something I'm dreading is that I already know that the rack is seized to one of the rack bolts. If anyone has suggestions for that too I'd be greatful.
I dont see the point in ordering just a replacement rack online. Go to a parts store like Autozone or Advance and get one, they will most likely have it in stock or get it next day, they are under 80 bucks and have a lifetime warranty, next time it goes bad you just go in with your receipt and get a new one, done deal. They are good quality too. Get new outer tire rods while you are there which they will have in stock and just order the poly bushings anywhere online.
EDIT: Working at Advance I would recommend you go to their website and use a coupon code and do a pickup in store.
If you are looking for aftermarket performance parts I would look else where, for OE style replacement parts such as, cooling system, steering, brakes, suspension, they will do just fine. I've worked there for 5 years while finishing school and I've seen which parts come back and which parts never come back. I replaced my entire steering system, rack, tire rods, pump, hoses from Advance for under 150 bucks, it was all in stock and when I have to replace something (haven't had an issue in 2 years) I go in swap it out and it's installed the same day. But, I really don't have to convince anyone, you go ahead and spend 250 plus shipping and wait for the rack, I will do just fine with my Advance steering parts.
Steering rack replacement
The two inner tie rod ends are usually what wears out, and at $45 each, it's better to get a replacement rack assembly since they are part of the package. The rack is about $100 + a $40 refundable core charge, which you get back when you return the old rack. Be sure to ask for the GT or high performance rack, it has fewer turns lock to lock than the standard rack.
The flex coupling for the steering shaft needs to be disconnected before you can get the rack out. You should disassemble the coupling by removing the 2 bolts that hold it together. The lower part of the coupling will then come out with the rack, and can easily be removed.
The tie rod ends can be removed with a tool that looks like a giant "pickle fork", it's less than $8, or some stores will rent/loan one. Remove the cotter pin & nut on the tie end, stick the tool between the rod end and the arm it connects and hammer away. The bigger the hammer, the easier it comes apart.
Remove the two bolts that bolt the rack assembly to the frame and then pull the rack down. Dropping the rack before attempting to remove the hydraulic lines with save you 30-45 minutes of fussing and sweating, and you’re going to have to remove them anyway. Get a catch pan to dump the fluid in when you disconnect the hydraulic lines. I replaced the rack mount bushings with some Energy Suspension urethane ones. When you re-install the rack assembly, put the rear bushings in the rack assembly and lift it into place. Then install the hydraulic lines, front bushings & washers and tighten down the nuts. Doing it this way makes room for the hydraulic lines without having them bind against the frame.
To change the tie rod ends, do them one at a time. Loosen the jam nut 1/4 turn, then unscrew the tie rod end from the rack. Turn the jam nut back 1/4 turn to return it to its original position. With the tie rod end removed, use a machinist square to measure the distance between the end of the threaded rod and the jam nut. Sit the bottom of the square against the end of the threaded rod, and the end of the blade of the square against the jam nut. Duplicate the measurement on the new rack and then install the tie rod end and tighten the jam nut. Then do the other side: the front end will need aligning, but the toe in will be close enough to the setting of the original rack to drive to the alignment shop.
Buy several extra quarts of fluid to run through the system to flush it when you change the rack. The car needs to be up on jackstands for the next step. Fill the pump up, start the car, and turn the wheels lock to lock to bleed the air out. Then stop the engine, disconnect the low pressure hose (the one that is secured with a hose clamp) and drain the pump. Re-connect, refill and do it several more times or until the fluid looks clear and not burnt or black.
Power steering pressure lines:
Each hose uses an O ring on each end to seal them. The hoses will swivel when they are installed and tightened into place. That is why there are O rings on the fittings. The O ring is the part that actually makes the pressure seal. If you slide the nut all the way back as far as it will go, you will see the O ring and the groove cut into the center section of the fitting.
attachment.php
Sometimes you will get some white Teflon rings with the pump or rack. The rings go on the threaded part of the fitting to reduce or prevent small leaks. They are not meant to seal the pressure part of the line or substitute for the rubber O ring. Heat the white Teflon seals in hot water and they will be easier to install. You can install the fittings without them and not have any leaks if the O rings seal good.
As always jrichker, thank you very much for your very helpful and detailed instruction:nice:
I'll be going with a parts house rack because well.... I'm poor. I'd imagine that all the part houses rebuilds are all about the same in quality. I'm not looking forward to removing the k-member bolt, I'll probably have to cut some of it out and air hammer the rest out.
I did like mob said, I picked one up at Pep Boys. The good thing was that it was a Ford part that was remanufactured. The bad part was that one of the inner tie rods was a little looser than I'd like. One side was tight the other wasn't so much. But it was better than my 155k stock one. I had a $25 off coupon so it ended up being like $60 or something like that.
The problem with remanned racks is, the rebuilders all seem to use the 4-cylinder torsion bar inside them, and the T-bar is largely what determines the input resistance, or steering stiffness/feel. The 4-cyl T-bar creates very light steering that's low on feedback. I've never seen a reliable way to get around this other than to find an OEM 5.0 or Cobra rack, and they're getting tough to find. AGR can technically do it but it seems like they'll :leghump: it up 17 times before you get a good one. Point being: Make your 5.0 rack last as long as you can.
I personally had the same thing happen to mine. POW and big puddle in the garage. I went to Auto Zone and ordered one which took overnight to get. They have several listed online. I chose the quick ratio one for the same price as the others and could not be happier. It turns easy and quick. I love it. And if I remember it was about $69.00 with the core exchange, so I took it off and took it with me.
I ended up ordering the quickest ratio rack from Autozone too, so I'm glad yours is holding up. I also did out tie rods and poly bushings.
