94 GT. AODE. When you let off the gas going down the road, it does not slow down on its own. The rpms stay where they were. It will do this for at least a mile. Probably more but I have not tried. It is like having cruise control on but it is not. When applying the brakes, it feels like the car does not want to stop. But, when I do stop, the idle is where it is supposed to be. I have a slightly higher than stock stall (2700) and before this issue, when I would be in gear and let off the brakes, the car would barely move forward by itself. Now, it will move fairly quickly without help.
I have replaced IAC, TPS, ECT, IAT, VSS, O2's, MAF, and did a full tune up. (All of that was done before this idle issue.) I even got a 2nd IAC to see if that was the cause. TPS is at .97V at idle. The only code I have is 327. I also tried the base idle reset.
Any help is greatly appreciated.
