I haven't many miles on my '66 EFI yet as I'm trying to get all the bugs worked out. When I start my car, I have to give it some gas to keep it running until it reaches about 110-130° and then it'll idle on its own at around 800-900 rpms. Okay, so I go to the surging idle checklist and find some great info.
Tried to set the base idle speed as per the instructions below, however, I have a slightly mild (unknown specs) camshaft which is giving me a headache. When I go to disconnect the IAC, the engine dies. Found Ranchero5.0's comment (below) and I cut a little slit between the two holes but it didn't seem to help the idle at all - when I drive and shift it seems to stay at the shifting point RPM for just a second longer. Not sure if I want to cut more into it as I fear it may make the idle hang more-so then it does now.
No vacuum leaks found.
Questions:
1) Has anyone cut their IAC for a cammed engine and have any pictures? I'm thinking maybe I haven't cut enough into the IAC...
2) Why does the car die when the IAC is disconnected? (is the idle way too low or is there another problem?)
3) Do I change the 600 base RPM to 900 for my application?
stock upper & lower intakes
stock heads, 302 with 8.9:1 compression
mild camshaft that is lopey at idle
No EGR, TAD/TAB (emissions)
quarterhorse (disabled emissions)
Questions:
Ranchero5.0’s comments on engines with other than stock cams:
A little dragon slaying lore here:
99% of the time on a cammed car opening up the divider between the ports on the IAC with a dremel so the motor idles at 1000rpm with the IAC unhooked, the throttle plate shut and the TPS at .98vdc fixes all surge related problems. Found about to do that on my '93 with a very mild cam and good induction it didn't like idling below 900rpm. The IAC can't react quick enough to a lopey cam induced RPM fluctuation so instead of dampening the surge it increases it. Every E cammed car I've ever worked on needed this to keep a stable idle. Similar to Fords idle bypass plate without the cobbled look. Just dremel out a little at a time till it idles around 1k. In my experience the stock puter doesn't like to idle a cammed car down low.
Setting the base idle speed:
First of all, the idle needs to be adjusted to where the speed is at or below 600 RPM with the IAC disconnected. Then the electrical signal through the IAC can vary the airflow through it under computer control. Remember that the IAC can only add air to increase the base idle speed set by the mechanical adjustment. The 600 RPM base idle speed is what you have after the mechanical adjustment. The IAC increases that speed by supplying more air under computer control to raise the RPM’s to 650-725 RPM’s
Remember that changing the mechanical idle speed adjustment changes the TPS setting too.
This isn't the method Ford uses, but it does work. Do not attempt to set the idle speed until you have fixed all the codes and are sure that there are no vacuum leaks. Warm the engine up to operating temperature, place the transmission in neutral, and set the parking brake. Turn off lights, A/C, all unnecessary electrical loads. Disconnect the IAC electrical connector. Remove the SPOUT plug. This will lock the ignition timing so that the computer won't change the spark advance, which changes the idle speed. Note the engine RPM: use the mechanical adjustment screw under the throttle body to raise or lower the RPM until you get the 600 RPM mark +/- 25 RPM. When you are done, reconnect the IAC electrical connector and re-install the SPOUT. Changing the mechanical adjustment changes the TPS, so you will need to set it.
An engine that whose idle speed cannot be set at 600 RPM with the IAC disconnected has mechanical problems. Vacuum leaks are the #1 suspect in this case. A vacuum gauge will help pinpoint both vacuum leaks and improperly adjusted valves. A sticking valve or one adjusted too tight will cause low vacuum and a 5"-8" sweep every time the bad cylinder comes up on compression stroke. An extreme cam can make the 600 RPM set point difficult to set. Contact your cam supplier or manufacturer to get information on idle speed and quality
