I am going to install an auxiliary power outlet in my '92 Mustang in addition to the stock cigarette lighter/outlet. Trying to determine the best way to wire this up. The instructions state to wire directly to the battery, as it has its own internal fuse. I'd rather not have it live all the time and have thought about doing it a couple of different ways:
Wire from battery to fuse to switch, then switch to outlet. This way it can be switched off until needed, then switched back off again. The switch would always have power but the outlet wouldn't. Benefit of this method is that the outlet could have power even if the car is turned off.
Wire from existing power source that comes on with ignition to fuse to outlet. Outlet would only work while car is on. If I go this direction, what would be the best source to tap power from?
I'm also open to other ideas and suggestions. Please let me know your thoughts. Thanks.
