iskwezm
already got a pusher and a puller.70_Nitrous_Eater said:100* is pretty hot...
Might be time to look into a pusher style electric fan to put in front of your rad. You can operate it manually with a switch for hot days..
36* is fairly typical for a performance tuned small-block.
Initial timing is set by twisting your distributor while measureing the timing with your timing light. Do it at idle with the vacum hose pulled off of your distributor (block it so you don't have a vacum leak).
Generally you want initial timing to be about 10*-12*
I know a decent amount of stuff,but if set initial at idle(no Vac adv.),does that change your total?Some guy told me to run 32*-34* on a stroker,but doesnt that differ with cams,heads etc.
