Is the base vortech kit any good?
Discussion in 'Power Adders' started by espv-250, Jan 26, 2004.
  1. espv-250 Founding Member
    Jun 25, 2002
    Message Count:
    69
    I've got a 91 lx notch. I've got a lot of money into it and the guy who had it before me put a lot of money into it. I want to supercharge it, but im going to college at the end of this semester, so I don't want to spend a lot of money. Plus, the motors all stock save for 24# injectors, 65mm TB and EGR plate, 75mm MAF, mac shorties, o/r h-pipe, and flows., along with new flywheel, centerforce dual friction clutch, aluminum 5" balanced driveshaft, and 4.10s with 31 spline mosers. I'm almost decided on getting the Vortech base kit for 5.0s, which comes with an SC-trim supercharger, but only runs the kit at 5 psi. To run more, what do i have to get. I know that I need a bigger crank pulley, an ignition retard box (where can I get one and how much?) and a bigger fuel pump(how big) but what else? Should I get a better ignition? Thanx, and sorry about all the questions?
    ~John~ :D
  2. blwnpony New Member
    Jul 29, 2003
    Message Count:
    37
    mooresville n.c.
    i have a 7" crank pulley and a 2.95 blower pulley and i am getting 14psi. i have a t-rex fuel pump with a 255lph in tank 4:1 disk in the fmu and 38lb injectors, all with the sc-trim...
  3. midnightrider New Member
    Mar 7, 2003
    Message Count:
    80
    IN
    If u r going to Supercharge, the first thing u need 2 do is get rid of those 4.10's...om
  4. bit Founding Member
    Sep 27, 1999
    Message Count:
    2,067
    Charlotte, NC
    Yeah it is a great kit! The only other mod my car had over your was a Cobra intake and the car made 304RWHP and 347RWTQ with only 5psi. If you want more boost just get a 7" crank pulley, a bypass valve, and a BTM is optional. With ported heads, Steeda cam, and the 7” crank my car makes 8-9psi in warm weather and a little over 10 in the cold. You can use the plastic discharge tube with a Bosch 110 bypass and it works great. You will have about $50 in the Bosch valve and the hoses and connections. You will need to buy a bleeder valve for the FMU boost line to adjust the FMU. The FMU is made to work with 19lb injectors but with the bleeder you can make it work with your car. You will be fine with the 4.10 as long as you get some slicks for the track and "drive" the car, if not you will never get traction.
  5. espv-250 Founding Member
    Jun 25, 2002
    Message Count:
    69
    thanx a lot guys, I have now decided to definatly get it, cool!!!
  6. RyanSG Founding Member
    Oct 24, 2002
    Message Count:
    666
    Allentown, Pa
    you'll love it i love my Sc-trim im runnen about 12 psi or so (haven't went over 3500rpm and it makes 6 psi at that) i still need injectors and a fue pump then ill be set. Good luck with it dude, have fun! :nice:
Share This Page
