Hey hows it going guys,
I just did a full rebuild on my 1994 Mustang 5.0 about 6 months ago, it is the first time i have rebuilt a motor, and am having some issues after the rebuild. Here is what the rebuild consisted of so you can get an idea of what was done to the car, and then ill go on to explain the issues that i am having:
Upgrades:
1. New upgraded cylinder heads
2. New 24LBS Injectors
3. Bored out .030 over with new pistons, bearings, etc.
4. Upgraded E303 Camshaft
5. Full offroad pypes exhaust headers all the way back
6. New fuel tank with upgraded fuel pump
7. Upgraded roller rockers
8. Upgraded lower and upper intake
9. New Piston Rods
Original Parts (That Have Not Been Replaced):
1. Crank Shaft
2. Block
3. Distributor
4. Intake
5. Electrical Components/Wiring
6. Computer
7. Lifters
Deleted Parts:
1. AC Compressor
2. Smog Pump
3. EGR
The car will start after the rebuild, but has no power and hesitates and occasionally dies. The vehicle has only died a few times and it was only when the vehicle was moving, it will run for hours just sitting in my drive way with no issues. I have been told that one of the reasons the vehicle acts this way is because it needs a chip and or because there is a vacuum leak. I have attempted to search for a leak by using carb cleaner and spraying it on vacuum lines to see if there is an idol change... but have found no leaks. I have been told that it could be a fuel issue, however i have replaced the fuel tank and the fuel pump and have cleaned the fuel rail - the issue still remains. I have noticed that the car will not start at times, unless you push the gas pedal and turn the car over it will eventually start. The starting issue will only occur if you turn it over and then stop before it gets a chance to start. I have noticed that the cars temp will start to rise at get close to over heating until the fan kicks on and brings it down to normal temp... not sure if that is because it needs a new fan or not... i have been told by a shop that that could be occurring from a timing issue which us causing the engine to overheat. Car runs very rich but im not sure if that is because of the EGR delete or not. If you have any ideas to what could be causing my issues please feel free to give me some input, it would be greatly appreciated. Again i am a rookie at all this, this is my first rebuild.
Thank you,
Hunter
Upgrades:
9. New Piston Rods
1. Crank Shaft
2. Block
3. Distributor
4. Intake
6. Computer
7. Lifters
Deleted Parts:
1. AC Compressor
2. Smog Pump
3. EGR
Thank you,
Hunter
