So I've been reading up on the J-mod and remember hearing awhile back that the reason you're supposed to turn OD off in a car while racing is because you can destroy the OD gear if it shifts at WOT due to some slippage. Will the J-Mod reduce/remove this issue as far as slipping or misshifting into OD and allow you to keep OD on? I know it firms up the shifts and reduces tranny wear so I'm assuming it helps the OD shift as well?
