Build Thread Jamee's Build Up Thread
Discussion in '1994 - 1995 Specific Tech' started by Jamee, Mar 26, 2010.
  1. Jamee
    Jamee Member
    Mar 12, 2010
    258
    Flint, Mi
    I tested for 12 volts at coil, there was. Haven't tested PIP sensor or TFI, didn't know you could
    I'm looking at the checklist right now, hopefully I can figure it out easily
    Ordered a new distributor, shouldn't have used a used one anyways.
  2. Zero Signal
    Zero Signal Active Member
    Feb 24, 2003
    2,640
    46
    Tucson, AZ
    You are sure you have the correct/working ignition module?
  3. Jamee
    Jamee Member
    Mar 12, 2010
    258
    Flint, Mi
    where is the ignition module? the black box with the heatsink under the intake tube? I have the one that came with the 5.0 computer harness
    looks like this:
  4. 94GTMustang5.0
    94GTMustang5.0 New Member
    May 29, 2009
    98
    yup, thats the TFI. mounted by the CAI on the passenger side fender.
  5. Jamee
    Jamee Member
    Mar 12, 2010
    258
    Flint, Mi
    Guess I'll look at that next :-/
    thankyou
  6. 3-0-II
    3-0-II Member
    Oct 24, 2006
    112
    17
    Redwood City, CA
    cool build!
    that motor looks absolutely slick
    man, seeing how fast you did all this is really making me feel bad for letting my EFI project go on so long lol
  7. Jamee
    Jamee Member
    Mar 12, 2010
    258
    Flint, Mi
    fast? you're mistaken lol
    it's taken me far too long :(
    but I'm very picky about vehicles I drive so I'm glad I've put the time into it to do things right
  8. 3-0-II
    3-0-II Member
    Oct 24, 2006
    112
    17
    Redwood City, CA
    trust me, its fast relative to my build lol :p
    im living away from the car right now so its been more than a year since ive even touched her
  9. 99FiveOh
    99FiveOh Advanced Member
    May 20, 2006
    2,045
    69
    J-Ville, FL
    I just wanted to mention that the probability of that TFI module being bad is slim. I've been driving these SN95's since 2003 and have owned about 5 of them, and in all the ignition problems I've had the TFI module was never the culprit. A lot of prior Fox owners will point to the TFI module because Fox's will eat through them like candy. When I drove one, I'd always keep a spare in the glove box with the correct tools to change it out roadside. Since Ford got smart and mounted the TFI remotely, away from heat in our cars, they hardly ever go bad.
    You are on the right track with the dizzy. Even if a new dizzy doesn't solve your issues, you can rest assured that you won't get stranded by the old dizzy failing(if it hasn't already). And please tell me you didn't purchase a rebuilt dizzy. I have gotten a few in my time that actually used the OLD pickup sensor! The very part that fails!!!! You can request a brand new one from Richporter and it's the same price, doesn't even have a core charge!
  10. Jamee
    Jamee Member
    Mar 12, 2010
    258
    Flint, Mi
    new distributor *didnt* fix the issue. Tested 12 volts at the coil again and it's not getting 12 volts, then it is getting 12 volts. I don't really know where to look. I have a couple connectors without anything connected, I'll upload pics of them later
  11. 99FiveOh
    May 20, 2006
    2,045
    69
    J-Ville, FL
    welcome to the world of mix and match Mustangs! get us those pics...
  12. Jamee
    Jamee Member
    Mar 12, 2010
    258
    Flint, Mi
  13. 99FiveOh
    May 20, 2006
    2,045
    69
    J-Ville, FL
    The first ones are for all the emissions solenoids that mount in the passenger fender. Having them disconnected will not cause any major issues, especially with spark.
    The second one I'm not sure of. Can you take a little wider shot of it's location so we can see what's around it?
  14. Jamee
    Jamee Member
    Mar 12, 2010
    258
    Flint, Mi
    That harness is behind the passenger side headlight, near the air filter and such
  15. Jamee
    Jamee Member
    Mar 12, 2010
    258
    Flint, Mi
    I have the v6 CCRM still, could that have anything to do with the lack of spark? :-/ Fuel pump works okay
  16. Chythar
    Chythar Well-Known Member
    Aug 26, 2004
    2,099
    12
    58
    West Los Angeles, CA
    The CCRM is different between the V6 and GT; Cobra has the GT CCRM. The CCRM controls power to the engine, the fuel pump and fan. So yeah, you'll need a GT CCRM.
    That second connector is for the A/C, there's usually a red insert in it. Again, won't cause you to lose spark.
  17. Jamee
    Jamee Member
    Mar 12, 2010
    258
    Flint, Mi
    kk ty!
  18. 94GTMustang5.0
    May 29, 2009
    98
    Let us know how the no-spark issue goes, and we want a video of that thing running!
  19. Jamee
    Jamee Member
    Mar 12, 2010
    258
    Flint, Mi
    why would my coil connector have positive and ground 12v when it's not plugged in but when it's plugged in I can't pull either voltage off the terminals?
  20. 99FiveOh
    May 20, 2006
    2,045
    69
    J-Ville, FL
    Hmm... with regards to the CCRM, when we converted my brothers 97 V6 to a V8 he used his V6 CCRM and it worked just fine.. The only thing that happened was when the computer told the CCRM to go to high speed on the cooling fan, the fan wouldn't run at all. So he did end up installing the correct CCRM eventually, but the car ran fine with the V6 unit.
    Now, did you buy a BRAND NEW never used distributor and not a reman? If you wanna test the dizzy, pull it out and rotate it while the key is in the "on" position. You should hear some clicks and the fuel pump prime. This will tell you if the PIP sensor in the dizzy is good. This has everything to do with the coil firing as well. If the PIP doesn't give the signal to fire, the coil won't do anything.
Share This Page
