sweet guys... thanks for the info... Well, I still don't really know what relays are ( i think i'd understand from a technical point of view, but i don't really know by name) anyways... the unit is just for the door locks and basically trunk... so it's a pretty cheap little unit with just a wire for the antenna which is about 2 feet long, that's why i was wondering if i hook it up to the real antenna
mine doesn't have a polarity switch, but i'm going to connect the 12V and ground and use a multimeter (voltmeter) to test polarities and whatnot before I blow anything up... so i'll be careful
thanks again guys, i think this should be some good info if somebody tries this thing again
by the way... my unit has build in fuses on (i believe... i'll check in the morning) the power, trunk module, and maybe negative/ground.. and a couple more... but that might be the "relays" you refer to, i'm just not that technical
rant: i'm a freakin 3rd year EE major, and i don't know what a relay is... how pathetic is that.... freakin universities and their theory over real life examples BLAH
/rant
