The CC plates will go in the same day so I can align it on Friday. I will install the bushings on Sunday...... now that I think about it I may want all the new bushings in the rear before I align it
It lets me tune the A/F ratio to get the most power out of the car without blowing it up or making it spit fuel out the tail pipesIm such a nood with the following quesiton
What can you do with you wideband? Does it give you tuning capabilities?
Stop lauging at me!!!
I just ment the three diff bushings. I KNOW if I replace them my diff will sit 1/8" higher wich is enough to possibly cause issues. Also I would like to just do all the work at once. So on Saturday I will install the bushings/CC plates/wideband and Monday have it aligned and have the sensor bung welded in.Cool. What other bushings? UCA/LCA and subframe??
You don't need an allignment after the diff bushings or subframe. But the UCA/LCA you would. I have been told that the subframe bushings are a royal PITA and are useless. Keep that in mind. My shop that I go to, just installed the stop the hop kit and the customer said it didn't do anything.
On a supercharged application like mine and with the way I am having my tune done it could net me 40+ hpwhat kind of gains can you see from a good AFR tune? That little thing looks awsome. i want one lol
The camera washed it out. The SVT is red just like the stock gauges are.Sure is purty
Can you change the color of the SVT on the screen? I like the 3D look but also like the SVT look if you can change the color. That yellow isn't doing it for me
Its needle looks the same too.
It will sit higher in mine because my bushings are so shot that 1/8" is how much compliance/space I have.I just got my bushings from UPS today. The directions are like 8 pages long. They want you to pull axles shafts and the diff itself....Eff that...you don't need to do all that. I'm just taking the front crossmember out and prying them out and installing the new ones. The rear one will be cake as well.
Where did you read that the diff will sit 1/8" higher?? I have never come across that. Let me know how they go because like I said, I'm waiting for my diff brace and would rather install both things at once.
