Pull the head light knob to "on".
Rotate knob until you can see the cut out on the side.
With pick, pull up on metal clip inside the cut out while pulling on the knob.
Remove 2 t45(? Cant remeber the size off hand) Screws at the top of the cluster bezel.
At edges, pull bezel to release the clips.
Remove 4 t45(?) Around cluster.
Pull cluster out enough to remove the two wire connectors at the rear top of the cluster, just press the tab down at the center of each wire connector.
At the back of the cluster, there are a series of twist knobs.
Those hold the cluster bulbs.
