Car is throwing codes 41 and 91.
I know from this post
http://forums.stangnet.com/788958-code-41-running-rich-brake-booster.html
that i should start with 02 voltage, and then wiring harness and then vacuum leaks. here is my issue. In that thread it says to pull the plastic cover off of the ECM. Does it just clip off, or is there a secret to it? My cage is in the way down there, and i have sort of limited space and i dont want to break anything. In the morning, i am going to do a quick carb cleaner vacuum leak test with the engine cold and see if i find anything.
what confuses me about the codes is they aren't being thrown at a specific time(full throttle, during idle) they just appear after i've been driving for a while.
I'm leaning towards a vacuum leak as this started when i installed the new motor. I've traced out all my vacuum lines. The car has no egr is it possbile something from the removal of that(it was gone when i got the car) could be uncapped and causing the leak? Thanks in advance.
