long tube or shorty with bolt ons... is it worth
Discussion in '2005 - 2009 Specific Tech' started by chad9350, Jan 24, 2007.
  1. chad9350 New Member
    Jan 13, 2007
    Message Count:
    253
    is the price worth the difference... any true numbers vs.?
    dyno or et?
    are long tubes too much flow if not changing intake (real intake, I have CAI ), cams, etc..
    any info. greatly appreciated.
  2. YELLOW42RCODE Member
    Feb 13, 2003
    Message Count:
    310
    Yes long tubes are worth the extra $ over shorties. They will be good for 12 - 16 rwhp with your set up.
    Fred :nice:
  3. 8850 Founding Member
    Jun 3, 2000
    Message Count:
    459
    I have examined three brands of shortie headers and none were made for maximum hp increases. They all had formed or crushed tubes where they are welded into the collector. You can't make hp when two of four tubes on each side are crushed down to something other than round. Also they had the 02 sensor protruding into one of the tubes on the drivers side. That 02 reduces one cylinder flow significantly verses the protrusion going into a collector as with the long tubes.
    If a shortie is made right it can flow good and give reasonable hp results. I ran a 10.65 with 1 5/8 ported shortie headers on my 88 347 Mustang. The 05+ headers I examined could not even be ported to produce round tubes. All appeared that to make the ID of the tubes round you would have produced holes in the outside of the collector.
    Until somebody makes a good shortie, get the long tubes!
  4. bigcat start with the upper hole, and if more traction is
    May 2, 2005
    Message Count:
    4,250
    78
    shorties are a waste of $$ for an S197, IMO. they dont net you much gain. the stock manifolds flow pretty well, so go long tube or go home.
  5. burke07gtcs New Member
    Jan 14, 2007
    Message Count:
    64
    I put SLP long tubes w/ x-pipe & love it , very good SOTP feel -the best fitting headers I have ever had, only 2 hrs. to install on my back -no lift
  6. chad9350 New Member
    Jan 13, 2007
    Message Count:
    253
    Ok, so...
    Do I need to drop motor mounts to install?
    O2 is in the collector, not just one tube?
    Thanks for the advice. :D
  7. YELLOW42RCODE Member
    Feb 13, 2003
    Message Count:
    310
    I had to on mine. I installed JBA's.
    Fred :flag:
  8. RhinoGT New Member
    May 23, 2006
    Message Count:
    46
    I am interested in hearing more about your install as I have the slp x and loudmouths and I am thinking about getting their longtubes.
  9. burke07gtcs New Member
    Jan 14, 2007
    Message Count:
    64
    I had to drop the right motor mount & undo the steering shaft. The O2 is in the collector not just one tube. If you buy the header kit it comes w/ O2 extensions & gaskets.
  10. 8850 Founding Member
    Jun 3, 2000
    Message Count:
    459
    Correction to my reply about the 02 in the tube of shorties. It is in the collector but in one maybe two brands I examined it covered one of the tubes so it might as well have been welded into the tube.
  11. iskwezm Well-Known Member
    May 24, 2005
    Message Count:
    3,944
    56
    my buddy agrres with this, luckily he bought his used and he said didnt notice a difference in driving or the dyno(or very marginal).
  12. StangGT2006 New Member
    Aug 13, 2006
    Message Count:
    18
    How much do long tube headers change the sound of an exhaust?
  13. kooldawg6 mine works really well and can take a fair amount
    Aug 31, 2006
    Message Count:
    1,718
    I would be more interested in the increase of power from the LTs than the sound. ARGH ARGH ARGH
  14. ALLOY2007GT New Member
    Nov 1, 2006
    Message Count:
    108
    LT headers will help put out an awesome sound. you will hear more clearly each individual cylinder and have a crisp deep rumble at idle. i cant wait to afford some mods.
    As far as power, the Shorties and LT dont compare. You may get 3-5 hp with shorties, but a well tuned LT setup can produce 20+ hp on the dyno. I know a local guy with LT, OR pipe and a JLT, steeda pulleys, that puts out around 315RWHP.
  15. kooldawg6 mine works really well and can take a fair amount
    Aug 31, 2006
    Message Count:
    1,718
    That's what I'm talkin' 'bout!!!!!:nice:
  16. anthony05gt New Member
    Mar 19, 2006
    Message Count:
    1,268
    Under hard acceleration you'll get more of a cracking sound. Like a firecracker on steroids.
  17. bamaster New Member
    Jul 31, 2001
    Message Count:
    51
    What's the effect of Long Tubes on emissions compliance?
    I have a catted MAC Pro Chamber on my car and I'd like to make some horsepower but not at the expense of failing emissions inspection.
Share This Page
