Did you get a code 67 when you dumped the codes? That would explain why you can't get the engine running codes to dump.
Code 67 –
Revised 2 Nov 2012 to add definition of the NSS functions for both 5 speed and auto transmissions
Cause of problem:
clutch not depressed (5 speed) or car not in neutral or park (auto) or A/C in On position when codes where dumped. Possible neutral safety switch or wiring problem. This code may prevent you from running the Key On Engine Running tests.
External evidence from other sources claims that a code 67 can cause an idle surge condition. Do try to find and fix any issues with the switch and wiring if you get a code 67.
What the NSS (Neutral Safety Switch) does:
5 speed transmission: It has no connection with the starter, and the engine can be cranked without it being connected.
Auto transmission: It is the safety interlock that prevents the starter from cranking the engine with the transmission in gear.
What it does for both 5 speed and auto transmission cars:
The computer wants to make sure the A/C is off due to the added load on the engine for the engine running computer diagnostic tests. It also checks to see that the transmission is in Neutral (5 speed and auto transmission) and the clutch depressed (T5, T56, Tremec 3550 & TKO)). This prevents the diagnostics from being run when the car is driven. Key On Engine Running test mode takes the throttle control away from the driver for several tests. This could prove hazardous if the computer was jumpered into test mode and then driven.
The following is for 5 speed cars only.
The NSS code 67 can be bypassed for testing. You will need to temporarily ground computer pin 30 to the chassis. Computer pin 30 uses a Lt blue/yellow wire. Remove the passenger side kick panel and then remove the plastic cover from the computer wiring connector. Use a safety pin to probe the connector from the rear. Jumper the safety pin to the ground near the computer.
Be sure to remove the jumper BEFORE attempting to drive the car!!!
Yes, I did get the code 67 during koeo. I know the NSS is disconnected. I have stuck my hand up on top of the tranny multiple times trying to figure out where to plug it in at...but I cant feel the connector. I need to get a little inspection mirror to shin up on top of the tranny to look.
Code 67 –
Cause of problem:
Thanks for the info! I did get the 67 error code. I expected it as the NSS is unplugged. I have had a heck of a time trying to find where it goes on the trans. All of the pics I have found shows it at the top front drivers side of the trans. I have felt all around the trans and can't feel anything. This weekend I was planning on bypassing it for now to see if that is the cause. I thought I read somewhere that as long as you have the clutch pushed in, the disconnected NSS is OK. I'm finding out from my research that it's not the case.
