What the hell happened?
A few days after properly disposing a Lexus G37 (nice car!), my '93 Mustang GT (mods in my signature - 120,000+ miles) started to have troubles. It started to leak oil kinda all over and "miss"; you can hear the engine miss a little during idle and it would sputter or "pop" when shifting. White smoke is also blowing through the tailpipe. It does not smell like burning oil, at least to me but i would assume that it is because oil levels drop after a short while.
While changing spark plugs, much to my dismay, I discovered that the #5 cylinder spark plug is oiled up pretty good. Also the header pipe that attaches to the #5 cylinder exhaust port is discolored brown. I went ahead and finished changing spark plugs,changed the O2 sensors and turned on the engine for long while reving it every now and then and i also drove it around. You can hear it engine miss and pop and sputter. The engine's timing is OK, TPS sensor is OK and all plumbing appears to be tight and secured. When reving the engine, the same white smoke blows through the tail pipe and it would still pop and sputter when shifting gears.
I am no professional mechanic but I am very tempted work on this, myself. I would definitely learn a thing or two. I've studied this car in and out since the beginning & i believe i have the necessary resources - like StangNet - in case i run into problems.
Questions:
Does this sound like a blown headgasket or #5 cylinder piston ring problem? Both?
Can the piston rings be changed without tearing deep into the engine?
What tools other than the usual garage tools would i need?
Thanks for reading.
Questions:
Thanks for reading.
