- Nov 29, 2004
- 113
- 0
- 16
I have what I believe to be an ignition (spark) problem. When the car sits for a a couple of hours, I will not get any spark when I hook a spark plug up to the coil. However if I put it on 200 amp jump start, it seems to wake it up and I start getting a ballsy blue spark again. At that point it starts and runs great. After it sits it does the same thing again.
So far I have replaced the following parts (which haven't changed the symptoms):
Fuel pump and filter (At first I thought it was a fuel problem)
Cap and Rotor
Coil
My next thought was the Ignition Control Module? Anyone ever replaced one? It looks like u might have to pull the distributor out and remove the distributor shaft to replace it.
The computer does not throw any codes/
Also is the PCM (powerterain control module) the computer?
Thanks in advance.
Cap and Rotor
Coil
Thanks in advance.
