Here is the plan. I cut a hole in the top of the tank. I plan to add a length of sheet metal that is 6 inches tall by two feet. I plan to drill large and small holes the entire length of the strip. I want to weld the strip to the bottom of the tank in a semi circle around where the pick up will be.
I am hoping that this will serve to keep enough fuel around the pickup during hard cornering and keep the pump from starving.
Any ideas??? Is there something I need to do to the new metal and the welds to stave off corrosion?
