Most Tedious 5.0 Improvement
Which is more time consuming?
  • Total voters
    33
I mount a pillar guage pod :)
I goto replace old Oil Pressure Sending Unit
Yes, the 93 goes straight into the block and is different.
Dry rotted POS breaks off in my hand :fuss:
So I goto parts store and figure out that a 1 1/16 socket fixes this problem
Crawl under car and take out old sending unit
Autometer supplied unit too big
Goto hardware store for brass extension
Fixed oil pressure sending unit :)
So I get the guages working.
Then I crank her over.
No electric fan. :fuss:
So I ripped out thermostat
Straight wired fan
Works great but engine doesn't like to shut off and alternator can't keep up :fuss:
I need a torch, a hand grenade, and a bazooka to finish :D
Strype said:
I'm there dude :nice:
What's a dcc controller?
*google*
Bro www.dccontrol.com my fan comes on at 10% when ignition comes on (3-4 amps) and ramps up and down as required to keep temp where I have it set..in my case 187* Never goes over, never runs 100% fan speed for more than a minute at most...even at 100 degrees outside, most often the fans at near 50% max output and charging system is VERY happy. There is at no point a spike on the charging system..infact it charges as well as it did prior to the fan install.
I must have this... yes, yes I will have this by next week :nice:
DMAN302 said:
Worlds biggest pain the ass...installing upper and lower control arms by yourself in 90 degree heat.
i thought i was the only one stupid enough to do that, it was around 90* wiuth like 90% humidity. i started off with work pants and a t-shirt but by the end of it i was down to only shorts. it also doesn't help that i have a short temper, wrenchs were thrown.
Talk about short tempered...
I was changing a front spring alone a couple of months ago- got it all the way up and go to adjust the jacks...
The a-arm was pivoted so that it was DANGEROUSLY stuck with the spring fully compressed. One side too high and the other one way out :fuss:
Took me till the next day to get the courage to fix it :lol:
I'm still here after that scary experience tho :nice:
and i pull up to his house, no lie........he has a saws all out, going to town on a comp eng. 90/10 drag strut cause he couldnt get the bolt off the top. now i got el cheapo struts...............im sure he had this all planned, knowing id eventually buy the car, he took the struts off so i couldnt hook and he can outrun me lol
LMAO- More than one way to skin a cat :D
