'66 Mustang with an '93 A9L GUFB style EFI setup. I have the quarterhorse by moates and binary editor from Clint. My problem is with the O2s, binary editor reports a steady voltage of .00125 from both O2s. I checked pin 29 and 43 at the back of the computer and both read ~.50 and fluctuating as they should. I have the non-HO firing order so I needed the quarterhorse to tune it with.
My KOEO: 15, 95 and then a 10 (Ford OBDI code reader from autozone)
My KOER: 41, 91
Engine passes multiple Cyl. balance tests
Either my computer (practically new) is toast or the software is not functioning correctly, because I'm getting the correct voltage readings for the EEC pins to the HEGOs and I've got 10.5+v to the HEGO heater wire in "RUN" position. I have double and tripple checked the HEGO wiring and can verify it is correct.
Any suggestions on what the next step would be?
My KOER: 41, 91
