1. American Autowire - Ford Mustang Parts - CJ Pony Parts
    The Classic Update Series is a complete wiring system in a box, giving you everything you need to modernize your classic Mustang's wiring system. Allows for most aftermarket accessories such as: gauge packages, heat and air conditioning systems, power windows, etc.
    Each kit features:
    - Correct replacement headlight switch with internal circuit breaker
    - Original Ford styled headlight switch connector
    - Headlight enhancement relays allow for high-powered halogen headlights
    - Separate relay controlled circuit for cars that have stock or aftermarket fog or driving lamps
    - Complete wiring for all running lights, brake lights, directional lights, license lights and third brake lights
    - Replacement ignition switch for use with original bezel and tumbler
    - Original style ignition switch connector
    - Standard turn signal flasher and hazard flasher mounted on fuse panel; horn relay mounted on harness
    - New ATO Fuse box fits the in center of the firewall away from header and A/C ducts and allows for easy fuse and circuit breaker accessibility
    - All required hardware supplied
    - Original switch connector bodies! (Exclusive to American Autowire)
    - Separate optional under-dash light sockets along with original dome/interior light wiring
    - New floor dimmer switch is provided and mounts in the stock location
    - Steering column connectors will plug directly into most aftermarket steering columns. Directions and an adapter with terminals are included for adapting a stock 1969 Mustang steering column.
    - Color schematics and easy to understand instructions included
    View attachment 183014 to our YouTube Channel to see more videos!!
