My 1990 Notchback Build Thread
Discussion in '1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk-' started by oatburner99, Jul 2, 2011.
  1. oatburner99
    oatburner99 Active Member
    Feb 20, 2010
    149
    15
    29
    Temple, TX
    My center caps are actually custom made by me.. :p had to do some trimming on the plain jane black center caps I got from American muscle. But they work great!
  2. FordRacing302
    FordRacing302 Active Member
    Oct 1, 2005
    384
    26
    39
    Cleveland, TN
    +1000 on getting rid of the GT bumper and maybe do something about the 4x4 stance it has....But other than that, Nice Car:nice:
  3. tannerc91gt
    tannerc91gt More durable than coconuts and twice as fast
    3,176
    454
    144
    Indiana
    What's the wording on the underside of the hood? Maybe i just can't see it
  4. oatburner99
    Feb 20, 2010
    149
    15
    29
    Temple, TX
    says "powered by SVOC" which is a very good friend of mine (owner of SVOC) and is a Shelby tech.
  5. oatburner99
    Feb 20, 2010
    149
    15
    29
    Temple, TX
    I've got to get the fender's rolled first before I can lower the car...already rub in the front. But yes lowering is on the list.
  6. SVT32VDOHC
    SVT32VDOHC waiting for the next hack atta
    Nov 22, 2001
    3,537
    21
    69
    Motor City
    Nice car. So you put the sensor from the small housing into the larger housing and it runs good? I was gonna do this on my old 91 notch, but a few people said it wouldn't run right.
  7. oatburner99
    Feb 20, 2010
    149
    15
    29
    Temple, TX
    From what I have gathered (this is my experience) that some car's do just fine. Other's don't run as well with the stock 70mm Cobra housing and stock meter installed. I installed my 55mm stock meter in the 93 cobra 70mm housing and noticed a drop in mileage as well as a rich condition. Now I have my cat's off as well as running a short belt (bypassing the smog pump) and it runs rich from that too. Another thing I noticed was that on startup the car would hunt a little bit @ idle until it warmed up. We have a big discussion on another forum about this situation. Some of the input has been that the 55mm meter obviously is reading (voltage) more air (due to the 70 mm size of the housing) but the computer cannot adjust ENOUGH for the fuel. The stock computer can only adjust so much (adaption) So what ends up happening is the car goes lean @ higher RPMS, which isn't good for the motor. Now I am researching now how a SN95 70mm housing AND SN95 meter work with the fox computer. Maybe someone can also chime in on this. I know it has alot to do with the voltage, airflow measured equates to voltage which is sent to the computer. The more airflow passing over the meter, the higher the reading in voltage. If the computer's max for reading airflow is "X" and you are actually flowing "Z" the computer can't understand that value because it's higher than it can adapt to. This is obviously is my understanding, so if I'm incorrect anyone please correct me!
  8. FoxGT87
    FoxGT87 Advanced Member
    Aug 1, 2009
    1,531
    103
    73
    St.pete FL
    Sounds like what happened to my car when I put an old Pro-m 87mm maf on there. I got back firing when i got on the throttle heavy or when i would let off the gas from getting on it. I figured it was because the computer wasn't making the fuel adjustments after taking the reading on much greater air flow coming in. I definitely think it needs a tune to run right with the 87 but that has to wait just like the rest of the engine build :mad:... trying to keep the motto in my head "do it once and do it right"
  9. oatburner99
    Feb 20, 2010
    149
    15
    29
    Temple, TX
    Installed these today with the help of a good friend:
    [​IMG]
    [​IMG]
    [​IMG]
  10. oatburner99
    Feb 20, 2010
    149
    15
    29
    Temple, TX
    Well went to the track last night. Track prep was lacking as usual. Next track night is going to be at Lonestar Motorsports Park, Home to Hennessey Performance. Alot better facility so I've been told. Anyway here's my times....went from a 14.7 last time out, to a 14.3, but still have alot of practice to do. Seriously lacking in the reaction time department, Uploading pictures and video now...in the meantime here's the times (keep in mind this is on street radials also:
    1st Pass
    Reaction=.5010
    60ft-2.53
    1/4=15.46
    mph=94.70
    2nd Pass
    Reaction=.8766
    60ft=2.26
    1/4=14.51
    mph=95.08
    3rd Pass
    Reaction=.5745
    60ft=2.28
    1/4=15.30
    mph=91.26
    4th Pass
    Reaction=.1138
    60ft=2.27
    1/4=14.73
    mph=94.24
    5th Pass
    Reaction=.5930
    60ft=2.50
    1/4=14.38
    mph=90.58
    6th Pass
    Reaction=.4371
    60ft=2.31
    1/4=14.64
    mph=95.28
    7th Pass
    Reaction=.4094
    60ft=2.35
    1/4=14.73
    mph=95.73
    8th Pass
    Reaction=.3655
    60ft=2.35
    1/4=14.49
    mph=96.65
    9th Pass
    Reaction=.6634
    60ft=2.557
    1/4=15.1
    mph-95.79
    10th Pass=
    Reaction=.8040
    60ft=2.32
    1/4=14.52
    mph=95.79
    11th Pass
    Reaction=.8094
    60=2.32
    1/4=14.52
    mph=96.26
    Pictures and video coming....as far as times...I did a 14.7 last time I went out...so making some forward progress with a 14.3 Still my times are all over the place...need to get consistent.
  11. TenorPlayinGuy
    Aug 3, 2001
    1,213
    36
    Canyon Country, Ca
    Man you got quite a few passes in! Usually I only hear about folks getting at most 4-5 runs. Good numbers too. I like the build, keep it going.
  12. oatburner99
    Feb 20, 2010
    149
    15
    29
    Temple, TX
    yeah, I tried to get as many as I could, trying to get consistent. But with it being 100+ even @ 10:00 pm it sucks.
  13. VibrantRedGT
    VibrantRedGT "STANGNET'S PENGUIN SMACKER"
    Super Mod
    14,516
    98
    114
    Boca Raton, Florida
    Holy Crap, last time to the track I got like 2 runs.
  14. NIKwoaC
    NIKwoaC 中國製造
    Oct 31, 2006
    5,209
    445
    164
    Chengdu Province
    I'm with these guys, getting 11 runs in is bad ass. I'm lucky to get 3, and that's with never getting out of line. Of course, test and tune night at my track is basically open season, you've got street cars, bikes, full blown race cars, etc. Fun to watch, but sucks to try to participate.
  15. FastDriver
    FastDriver Mustang Master
    Sep 5, 2001
    3,000
    185
    84
    Xenia, OH
    Super nice garage! Oh, and you must've been at the nascar drag-strip the way you were hot-lapping it. Practice your launch and stuff on the street (somewhere safe), and then when you go to the track, use and ice-pack on the intake and let the car cool for 30 minutes or so between runs. Right there, you're going to pick up a couple of tenths and a couple mph.
  16. oatburner99
    Feb 20, 2010
    149
    15
    29
    Temple, TX
    it's against TRACK RULES @ little river to ice your intake....get's water on the track....
  17. ViperPunk
    ViperPunk Member
    Jul 30, 2010
    196
    18
    idaho
    you can buy insulated freezer packs that are made to keep in the ice chest and then be thrown onto the intake to prevent that and still get the same benefits
  18. oatburner99
    Feb 20, 2010
    149
    15
    29
    Temple, TX
    Alright no more 4 wheeling for the notch. Picked up a set of Saleen Racecraft springs, and me and my buddy Justin put them on this morning. Went on with no problems. Only worry that I had was that I have a REALLY REALLY steep driveway, and I was worried about scraping while trying to get the car in the garage. But I squeaked by. Overall the springs feel awesome. The car handles like it's on rails (in combination with the subframes) but the ride isn't bone jaring or beat you to death. Very happy with the outcome. Only thing I've got to work out a little more is roll the fender lips. Still rubs on the tire, in the front and the back. Easy enough fix. Excuse the cell phone pics, the sun was STUPID bright early this morning which caused the glare. Here's some pics:
    Springs:
    [​IMG]
    Before the spring install (at Reborn's house)
    [​IMG]
    [​IMG]
    [​IMG]
    Stock vs Saleen's
    [​IMG]
    Out with the old:
    [​IMG]
    All done:
    [​IMG]
    All installed got glare? :
    [​IMG]
    [​IMG]
    [​IMG]
  19. Adams91LX
    Adams91LX Active Member
    Dec 9, 2003
    696
    12
    29
    Plano, TX
    you are on westsidemustangs too yeah?
  20. oatburner99
    Feb 20, 2010
    149
    15
    29
    Temple, TX
Share This Page
