My 1990 Notchback Build Thread
Discussion in '1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk-' started by oatburner99, Jul 2, 2011.
  1. oatburner99
    oatburner99 Active Member
    Feb 20, 2010
    149
    15
    29
    Temple, TX
    Lars, yeah went to TAD....not going there again...unless I pick up a set of DR's or slicks....just can't get traction, and it's not worth smoking a set of perfectly good radials.
    #141
  2. oatburner99
    Feb 20, 2010
    149
    15
    29
    Temple, TX
    Basically, 94-95 spindles, used some washer's for the lower ball joint (to compensate for the cotterpin) picked up a adapter for the passenger side brake line from LRS, brake caliper's from a Mach I (if I remember correctly) you might want to prepare yourself for a garage alignment, in order to get you down to a shop to have a real one done. Other than that, new pads shoes.....bled the brakes....been working great :)
    #142
  3. TOOLOW91
    TOOLOW91 Mustang Master
    3,095
    1,083
    154
    S.I.NY
    how about master, booster and prop valve all stock ? does it stop much better even with the drums out back still ? Sorry for all the questions just trying to get a feel for exactly what I am in for lol
    #143
  4. oatburner99
    Feb 20, 2010
    149
    15
    29
    Temple, TX
    I kept all the stock stuff (master, booster, etc etc) and yeah it does stop better. going from 4 lug baby stuff, to 10.8 size rotors do help :)
    #144
  5. oatburner99
    Feb 20, 2010
    149
    15
    29
    Temple, TX
    fixed the timeslip pictures :)
    #145
  6. oatburner99
    Feb 20, 2010
    149
    15
    29
    Temple, TX
    Cleaned the ole bucket of bolts up:
    [​IMG]
    [​IMG]
    #146
  7. fess40
    Nov 17, 2001
    283
    Paris, Illinois
    Cleans up quite nicely!
    Sent from my DROID RAZR using Tapatalk 2
    #147
  8. rangerboy101
    rangerboy101 Active Member
    Oct 11, 2011
    315
    20
    28
    Inwood, WV
    Needs clear headlights. ;)
    #148
  9. oatburner99
    Feb 20, 2010
    149
    15
    29
    Temple, TX
    they are, just shadowed in the pictures :)
    #149
  10. Vaz88GT
    Vaz88GT Active Member
    Apr 8, 2012
    265
    27
    38
    I want a notchback so so bad
    #150
  11. oatburner99
    Feb 20, 2010
    149
    15
    29
    Temple, TX
    lol
    #151
  12. oatburner99
    Feb 20, 2010
    149
    15
    29
    Temple, TX
    After the H/C/I my lil coupe is running STUPID rich...If I fire it up in the morning, go get my coffee and come back outside, it's like walking into a wall of fumes. I have an adjustable fuel pressure regulator on order, should be here next week some time. Anyway that won't do me any good if I don't have one of these. As expected 44 psi (vacuum off) So running fat....
    Kit from LRS
    [​IMG]
    Where it get's installed. This kit doesn't require you to remove the actual schrader valve out of the housing. The blue adapter has a nipple that actuates the schrader valve once you
    screw it on:
    [​IMG]
    About ready to install. had to put teflon tape on the gauge threads. BTW, in the instructions it tells you at least 3 times not to over-tighten the gauge or the fittings.
    [​IMG]
    Installed. Sorry crappy camera phone :p
    [​IMG]
    [​IMG]
    Hopefully have it dialed in a bit more, get it back down to 39 psi where it supposed to be. Been going through fuel like crazy.
    #152
  13. RacEoHolic330
    RacEoHolic330 I like to dress like a pretty girl
    SN Certified Technician
    Mar 4, 2003
    3,572
    822
    153
    Allentown, PA
    That's a nifty gauge setup. Wish I knew something like that existed when I had my stock rails.
    #153
  14. NIKwoaC
    NIKwoaC 中國製造
    Oct 31, 2006
    5,194
    437
    164
    Chengdu Province
    Do you have a wideband A/F sensor/gauge? I wouldn't go attempting to lean the car out unless you know for sure what your A/F is.
    #154
    oatburner99 likes this.
  15. oatburner99
    Feb 20, 2010
    149
    15
    29
    Temple, TX
    No I don't have one. However, I don't think it would hurt to set it to at least the factory 39 psi? I was under the impression, with the installation of the cam = less vacuum, which in turn creates a rich condition?
    #155
  16. NIKwoaC
    NIKwoaC 中國製造
    Oct 31, 2006
    5,194
    437
    164
    Chengdu Province
    The fuel pressure regulator's job is to maintain a constant pressure difference across the injector. If manifold pressure goes up, fuel rail pressure increases to match it. It does this because it is the difference in pressure that determines the fuel flow, and by maintaing a constant gap between manifold pressure and rail pressure, you know that your fuel flow rate is constant. If fuel flow is constant, then all you need to fully control A/F is injector pulse width.
    So what I'm getting at is that your fuel flow rate likely hasn't changed. It is possible that the computer has opened up pulse width to compensate for your mods, and toying with fuel pressure to correct AF at idle may hose you at WOT. So I would recommend a wideband to make sure you know what is going on everywhere.
    #156
  17. NIKwoaC
    NIKwoaC 中國製造
    Oct 31, 2006
    5,194
    437
    164
    Chengdu Province
    #157
  18. NIKwoaC
    NIKwoaC 中國製造
    Oct 31, 2006
    5,194
    437
    164
    Chengdu Province
    #158
  19. RacEoHolic330
    Mar 4, 2003
    3,572
    822
    153
    Allentown, PA
    Triple post fail!
    #159
  20. NIKwoaC
    NIKwoaC 中國製造
    Oct 31, 2006
    5,194
    437
    164
    Chengdu Province
    Triple post fail AND when I tried to make a post making fun of myself, it wouldn't let me post. So I gave up.
    #160
Share This Page
