Today I worked on the front bumper some more. I'm using a fiberglass support from a newer fox, so had to modify the mounts and make allowances for the marker lights. I used the later mounts, but modified them to drop the support down an inch to be at the right height. I had to also drill them for the through bolts since the newer style use the front flange mounting. Once the bumper was in the correct position, I put the nose back on and marked the location of the marker lights on the bumper. After removing the nose once again, I cut out the fiberglass to let the market lenses fit in. I still need to make up some brackets to actually mount them.
Old verses new bumper bracket.
I did a bit more trimming after I took this picture so the lens can be slipped in from the back after it's all together.
