Progress Thread My Kenne Bell Twin Screw'd Foxbody thread, (new addition to the family)
I'm Curious as well. It was my understanding that the coil was constantly hot and as the rotor spun, power arcs to each post in the cap.
This may help you understand:
TFI Ignition Control
Judging by that diagram, the PIP is crank position, and doesn't correlate with power to the coil.
I also installed my new coil and for crying out loud I still have no dang spark!
Will a bad PIP prevent the coil from working? I was looking at @jrichker 's cranking ok no start list and I'm trying to understand how things work. Does the PIP tell the coil to spark?
Yes...
How the TFI ignition works in 86-93 model Mustangs:
Tools needed: DVM, noid light, safety pin.
Theory of operation:
The TFI ignition in 86-93 Mustangs has 4 main components: the ignition switch, the coil, the TFI module and the PIP sensor inside the distributor.
The ignition switch gets power from the two yellow wires that are supplied power by a fuse link located in the wiring harness that connects to the starter solenoid.
I.) The coil is mounted on the driver’s side strut tower on most EFI Mustangs. It gets power from a red/green wire and a brown/pink wire from the ignition switch. That wire from the ignition switch feeds a 20 gauge blue fuse link that connects to the red/green wire. The fuse link protects the wiring and the ignition switch, since the fuse link for the two yellow power supply wires has a much higher current rating. Without the smaller fuse link protecting the smaller wiring used in the ignition circuit, a short there would cause the red/green wire to overheat and burn up.
II.) The TFI module is mounted on the side of the distributor and supplies the ground for the coil. Every automotive power supply circuit uses the ground as the return path to carry power back to the negative side of the battery. The TFI switches the tan/yellow wire coming from the coil to ground. It gets power from the red/green wire when the ignition switch is in the Run position. The red/lt blue wire supplies a signal to turn on more power (dwell time) when the engine is cranking. The increased dwell can cause excessive current draw if the red/blue wire remains energized when the ignition switch is in the Run position. The trigger signal comes from the PIP sensor when cranking and the computer when the engine is running. The SPOUT jumper plug enables computer controlled spark advance. When the SPOUT is removed, spark advance is locked at the setting determined by the mechanical position of the distributor.
III.) The PIP sensor is in the bottom of the distributor under the shutter wheel. It is a Hall effect magnetic sensor that senses a change in the magnetic field when one of the slots in the shutter wheel uncovers the sensor. Then it supplies a pulse that triggers the TFI module to provide a ground to the ignition coil. A bad PIP will often set code 14 in the computer and cause hot start problems. Replacing the PIP sensor requires removal of the distributor and pressing the gear off the distributor shaft to expose the sensor. For most people, a remanufactured distributor ($55-$75) is the solution, since they may not have access to a press.
IV.) Troubleshooting the ignition system – no spark or weak spark. All the tests are done with the ignition switch in the Run position unless specified otherwise. A safety pin may be used to probe the wiring connectors from the back side.
1.) Check for 12 volts at the yellow wires on the ignition switch. No 12 volts and the fuse link near the starter solenoid has open circuited.
2.) Check for 12 volts on the red/green and brown/pink wires coming out of the ignition switch. No 12 volts, replace the ignition switch.
3.) Check for 12 volts at the ignition coil. No 12 volts and the blue 20 gauge fuse link has open circuited.
4.) Check for 12 volts at the red/green wire on the TFI module. No 12 volts and you have wiring problems.
5.) Remove the small red/blue wire from the starter solenoid (looks like it is stuck on a screw). This is a safety measure to keep the engine from turning while you are making measurements. Have a helper turn the ignition switch to Start and look for 12 volts on the red/lt blue wire on the TFI module. No 12 volts and you will have starting problems, but push starting the car will work OK. No 12 volts, replace the ignition switch. Be sure to reconnect the red/blue wire to the starter when you finish.
6.) Check the red/blue wire to make sure that it has less than 8 volts when the ignition switch is in the Run position.
7.) A noid light available from any auto parts store, is one way to test the PIP pulse. The computer uses the PIP signal to trigger the fuel injectors. The noid light plugs into the fuel injector harness in place of any easily accessible injector. Plug it in and it will flash if the PIP is working. No flash from the noid light and the PIP is suspect. To confirm the PIP is being the source of the non flashing noid light, look for 12 volts on the red injector wiring. Good 12 volts and no flashing noid light means the PIP has failed.
8.) Remove the SPOUT plug from the harness and try to start the engine. If it starts, replace the PIP. This is a common no start condition when the engine is hot.
9.) The TFI module is a go/no go item when you have a no spark/weak spark condition on a cold engine. It either works or it doesn’t.
The TFI failure mode on a running car is usually a high speed miss on a warm engine. Many auto parts stores will test your TFI module for free. Bring along a hair dryer to get it hot while testing it and run several test cycles, since it often gets weak when it heats up.
The coil is somewhat more difficult to pinpoint as a problem. A good coil will make a nice fat blue spark 3/8”-1/2” long. The problem is that one person’s perception of a fat blue spark looks like may not be accurate enough to spot a weak coil. The coil is cheap enough ($13-$16) that having a known good working spare might be a good idea.
diagram courtesy of Tmoss & Stang&2Birds
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds (website host) for help on 88-95 wiring Mustang FAQ - Wiring & Engine Info Everyone should bookmark this site.
Ignition switch wiring
Vacuum diagram 89-93 Mustangs
HVAC vacuum diagram
TFI module differences & pinout
Reactions: 1 users
@jrichker
Awesome write up/explanation of the Ford TFI system and that answered my question perfectly!! I'm just going to pull my fancy MSD distributor that came with the car when I bought it and replace it with my perfectly good working stock distributor from my previous T-top 5.0 that ran just fine before I parted it out. I knew I'd need the distributor as back up just in case the MSD lived up to it's reputation, glad I did.
Reactions: 1 user
Well yesterday I tried my other distributor that I removed from my old perfect running T-top before parting it out and it was a no go. Still no dang spark. Guess I need to dig a little deeper tonight. Because I'm getting ticked off at my car I stopped by Exhaust Solutions today which is a hot rod builder and chassis dyno shop to see about getting my car in there. He's a couple weeks out which is fine. I'll keep trying to get my car to work but If I can't figure it out soon it's getting towed to the shop and paying the big bucks to get it finished.
Car have a 6al in it too ? If so bypass it
Reactions: 1 user
Nope, no 6al. I'll keep at it but the wife is nagging me to start my summer home improvement projects . I give the stang a week or it goes to the shop. I was also thinking about just taking it to a regular repair shop and have them fix the no spark then I can tow it home and fire up the engine and get tuning. That way would save me lots of money. What do you guys think?
Could it be an improper setting in tuner studio?
I should post my tune on stingers site so wes k can take a look at it. I'm using the base tune and set my engine displacement and injector size. That's it.
I'm not sure if I remember correctly but didn't you do something with the wiring in the steering column? And move the coil pretty far to one side.? I guess my question is, could it be in the wiring? Lol :chin
I did not extend any wires except the coil harness red/yellow and green/yellow wires and they both read 12v at the plug. I have skipped around the cranks ok but no start but it's time to strictly follow it.
Rereading the PiMP instruction this morning and was reading the part about installing jumpers for the various options available. Not sure if I remember installing the ignition jumper required. I'm hoping that I skipped that part and that's my problem as it'd be the easiest fix!
Reactions: 1 user
Yep, also helps if I can start something and finish it without interruption.
I read instructions and plug a couple jumpers in then I hear screaming in back yard so I check on kids, 6 y/o climbing fence, check, 2 y/o twin #1 eating sand in sand box, check, twin #2 wants sand that twin #1 is eating and is upset about it. I go back in garage and read some more instructions and plug a couple more jumpers in and then I hear screaming again, go in back yard, 6 y/o is playing on tire swing, twin #2 is hitting twin #1 with plastic toy shovel. Take shovel away and get back in garage, more reading, more jumpers and then I hear nothing, it's perfectly quite, something has to be wrong so I check on kids again........
It's the good life.
Reactions: 1 users
So from what Shannon and Wes K say over at Stinger is even if I didn't install the jumper I would still get spark when the spout is removed. The spout, when removed, takes the ECU out of the equation.
