I am currently swapping a 89 5.0 into an 84 cj7 and would like to know what are all the sensors i need to make this thing run properly. I am getting rid of the smog stuff, as well as teh A/C. So basicaly i need just the essential sensors. Thanks.
I have been lookign at that site as well, but it deosnt seem to have a very good step by step of what a install needs.
Great about the docs. My email is [email protected]
That would be great I need all the help I can get since I am also going to make the EFI swap this winter. Thanks for the help my email is [email protected].
I used it when I installed the EFI in my '65. The wire and connector colors in the manual are a perfect match for a '92 5.0 wiring harness. You might have to do a little interpretation for an '89 harness, but it'll get you close. Good luck.
Thanks, I just got this from somebody as well. I already read it over and this job seems pretty dang simple. The only thing I need is to find a barometric sensor. Anybody know where I can get one. New onse are freaking expensive. Thanks gusys
red65 said:
This manual is about the best step-by-step resource that I've found.
i wouldn't call the swap easy by any means. be prepared to do a lot of work to get the power circuits done correctly (if you're doing it according to the fordfuelinjection.com recommendation of 4 relays).
