All the valves under the dash are vacuum controlled, and the default when you have no vacuum is to defrost. You probably have a vacuum leak. The vacuum line that goes to the AC controls is a small line, about 1/4" diameter that runs down the firewall from the vacuum tree on driver's side inner fender to the passenger side of the vehicle. Usually that's the line that gets a leak in it.
Kurt
