Need Help
Discussion in '1994 - 1995 Specific Tech' started by joeltx_2000, May 18, 2014.
  1. i got the reverse glow gauges from amerincam muscle tried to hook them up on my 95 gt over the weekend . i followed the intructions but they do not light up , anyone have any ideas ? please help
  2. Try connecting the leads from the gauges to 1 9v battery to see if it lights up. You might have a bad unit. More likely you have a wiring issue. Which wires on the light switch did you tap into? And how did you tap into them?
  3. well in the instructions it said to the thick grey wire that goes to the middle of the block on the headlight switch but on mine it's a brown wire and i had seen where someone on american muscle website that confirmed the wire is actually brown and i connected them with wire connectors and grounded it to the unpainted metal plate underneath the sterring colum
  4. To be honest I don't recall the wire color I tapped into (it's been a few years), perhaps someone else does. But I'm definitely sure it was a thin wire, and I had to use one of the smallest connectors (the little red one). I'd suggest some old-fashioned electrical troubleshooting. You'll want to use a voltmeter to see that you're getting good voltage and ground from your wire-tap and where you grounded it to the plate (which should be fine). If that's good, then you'll want to check the function of the gauges for which I suggest a known good voltage source (9V battery is the easiest).
  5. Check out for wiring scematics
  6. Alright thanks for the help guys , I'm gonna try it again this weekend
