Need some help guys...car related
Discussion in 'WC Classifieds' started by SQUEEZE&STROKE, Jun 2, 2008.
  1. SQUEEZE&STROKE New Member
    Jun 24, 2005
    Message Count:
    631
    SOUTHERN CA
    I am thinking about selling/trading the stang.
    I never drive it, and it has only had about 4 miles, yes only 4, since I put it all together. It runs like a beast, but I dont get to enjoy it. I want something I can drive everyday.
    I spent about $13,000 last year alone on it.
    I KNOW I will not get what I have in it out of it, but it is easily over 25K at this point. What does everyone think a fair price to list it as/trade for.
    I AM VERY OPEN TO TRADES. I am hoping to find a newer GT/Mach/Bullit/Cobra.
    It has the following mods:
    Moser 33 spline axles with c-clip eliminators
    Moser 33 spline spool
    Ford Racing 4.30 gears
    Ford Racing rear end girdle
    BBK rear upper and lower control arms
    Strange engineering Pinion yoke
    Strange engineering custom length Chrome-moly driveshaft
    Strange engineering hardened driveshaft yoke
    Mike’s Transmission ultimate C-4 with transbrake, multiple clutches, hardened output
    B& M 28 oz flexplate
    JW “The Bell” blowproof bell housing
    Moroso finned aluminum transcooler
    B&M deep trans pan
    Hitachi 360 degree clocking mini starter
    Canton Drag pan with crank scraper and kickout
    Canton Oil Pump pickup
    Standard volume oil pump
    ARP Oil pan studs
    Early 80’s 302 block professionally decked, line honed, and machined by FPS
    Eagle 331 crank, I beam Rods, SRP Pistons
    Canfield Avenger CNC’d head-2.100 intake, 1.70 exhaust (Flow 322 cfm @ 600)
    AFM N-111 cam
    ARP Cam Bolt
    All engine bearings Clevite H-race series bearings
    Speed Pro file fit rings
    Ford Racing Timing chain
    FPS main girdle with windage tray and ARP Main Studs
    Parker Funnel Web intake
    Holley 750 HP carb
    Aeroquip Stainless #8 carb lines and swivel fittings
    Ford racing valve covers
    ARP valve cover studs
    CSR Billet throttle cable bracket
    CSR Billet Electric water pump
    CSR Billet water neck
    CSR Billet fuel pump block off plate
    Ford Racing Vacuum pump
    Aeroquip stainless #12 hose and swivel fittings on Vacuum system
    Moroso Aluminum Catch can
    Comp Cams 1.72 rockers
    ARP Rocker studs
    Comp Cams Rocker stud girdles
    Comp Hardened CORRECTLY MEASURED pushrods
    Cometic Head gaskets
    ARP Hardened oil pump driveshaft
    MSD Billet Distributor
    MSD 6AL
    Bassani 1 & ¾” to 1 & 7/8” stepped headers
    3” Bassani x pipe
    3” bassani flow tubes
    3” Spin tech mufflers
    Global west full length subframe connectors
    D & D tubular K member
    D& D tubular A-arms
    D& D coilover kit
    QA1 175lb 14” coilover springs
    Lakewood 90/10 front struts
    UPR Billet aluminum caster/camber plates
    PP Billet regulator
    Holley blue fuel pump (-8 feed line)
    Moroso 8” fuel filter
    Mallory fuel pump pickup
    Flaming river manual steering rack
    Strange engineering manual brake Master cylinder
    Moroso Line lock
    Precision Performance billet shifter with integrated neutral safety and transbrake switches
    Kirkey pro street drag seats
    Kirkey black tweed covers
    Autometer Fuel pressure, oil pressure, water temp, trans temp, Pro shift light stage 3
    Autometer dash clock pod, a pillar pod, steering column pod
    Painless Performance 8 switch panel (car was professionally wired)
    All interior pieces there
    Moroso main power disconnect switch in rear bumper.
    HO Fibertrends Cobra RR pin on hood
    Weld Prostar wheels, 3.5” up front, 9” out back, with an extra set of rear wheels w/tires
    Factory Ford color DSG paint (Few months old)
    NO DENTS AT ALL. Maybe a few small scracthes here and there.
    Thanks guys
    Pics
    [IMG]
    [IMG]
    [IMG]
    [IMG]
    [IMG]
  2. Gearbanger 101 That's my secret, Captain. I'm always angry!!!
    Aug 11, 2002
    Message Count:
    11,308
    52
    98
    Ontario, Canada
    Bad ass looking ride, but are you sure you posted this in the right classifieds section? :scratch:
  3. SQUEEZE&STROKE New Member
    Jun 24, 2005
    Message Count:
    631
    SOUTHERN CA
    Thanks Gear Banger...:nice:
  4. SQUEEZE&STROKE New Member
    Jun 24, 2005
    Message Count:
    631
    SOUTHERN CA
Share This Page
