i just installed a reman'd engine and i have one huge problem, i have no idea where the ground for the negative battery cable goes, currently i have it between the block and the motor mount, however, i still have insufficient power to start the car and only get one crank from the starter. the car however, does start with a jump the start engages as it should, and the engine will turn over but will cut off immediately after unless the throttle is held at 1000 rpms. the alternator is good and the starter has been ruled out, one suggestion was that there was a dead cell in the battery however multiple batteries where used. im convinced that this problem is a ground issue if any one can help out or send pictures it would be greatly appreciated i just need to see where you guys would have that cable located its on the driver side i have it one bolt under the ground strap on the motor mount.
