mikestang63
SN Certified Technician
Well checked PTV Clearance and failed with stock pistons. It tore thru the clay guess trying to use a stock bottom end was a bad idea. Anyone have a recommendation on a set of pistons with better valve reliefs. Thanks
That is odd that those heads won't work. I had those same heads on a car and they bolted right on without a hitch, even with 1.72 RR.
Isky sells a piston notcher that you can use with the pistons in the motor or of the motor. It helps if you have an old spare head to use as a guide tool.
